No Tapping fluid available, any suggestions for a substitute?
Discussion in 'The Garage' started by mr.smartass, Jan 7, 2007.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    Went to Sears and Wal-mart (only places open at the time) but neither had any type of cutting or tapping fluid or oil... I'm just wondering if there is anything thing else I could use as a substitute, I've got to drill a few 3/8 holes into some flat 1/4 inch plate, I've already got a cobalt drill bit from sears. Any Ideas?
  2. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    motor oil works for me.
  3. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Any light oil with a high smoke temp.
  4. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    ATF works excellent.............
  5. 454k30
    454k30 1/2 ton status GMOTM Winner
    Sep 13, 2004
    1,613
    California, MD
    motor oil, gear oil, lucas oil, something that doesnt catch fire instantly.
  6. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ive used marvel mystery oil & WD40, though the wd40 evaporates too quick.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I have WD-40 but gear oil works well also. It kinda stays put:D.
    Ira
  8. Slapperbar
    Nov 29, 2005
    2,747
    3
    Tap Magic.
  9. BB402Blazer
    BB402Blazer Newbie
    Jan 7, 2007
    3
    Granite Falls, WA
    I would assume that an auto parts store would carry cutting oil before walmart and sears would.
  10. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    yeah well it was late and the autoparts stores were closed. I stepped up through a few bits but once i got to the bigger ones i could not get it to drill any more, I'm using a drill press, are the rpms to low or what??? I had to find thinner metal...
    oh yeah and who carries tap magic or something like that? I haven't seen it at any parts stores...
  11. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    pb blaster! high flashpoint and works great
  12. Slapperbar
    Nov 29, 2005
    2,747
    3
    Try about 900-1000 RPM.
    Granger or MSC
  13. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    900-1000rpm? its for tapping holes, right? you dont tap at 900 rpms... and my cordless drill never smoked out with blaster, and i cut 1/2" holes in 1/4" plate...
  14. Slapperbar
    Nov 29, 2005
    2,747
    3
    Drill at that speed.
  15. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    do you really need anything to drill such a small hole through such thin material? I would think that starting with a smaller bit like 3/16th and then going to 3/8 would be enough. I use tapping fluid for just that, tapping. or am I missing something?
  16. Slapperbar
    Nov 29, 2005
    2,747
    3
    Usually for drilling you need to cool the drill bit to keep from fooking it up on stainless or thicker materials.
  17. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
    If it wouldn't drill anymore, either your bits were dull, or the metal "work hardened", that is to say it became harder through the repeated heat/cooling of drilling consecutively larger holes. You need to increase step size and also increase rate of feed.
    Jimbo
  18. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    could always use a torch or plasmakutta and blast a hole then use the drill to clean it up...heh
  19. garlicbreath
    May 17, 2003
    1,136
    Denver
    Oh yeah, drill bits LOVE to clean up those holes!:mad:
  20. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    sry meant the drill w/ a carbide burr..
