No Temp gauge
Discussion in 'The Garage' started by skyrocco16v, Mar 28, 2006.
  1. skyrocco16v
    skyrocco16v Registered Member
    Jan 17, 2004
    14
    hey guys, ive got a slight problem with my temp gauge, in the fact that it stopped working, could the sensor in the top of the intake be bad? if so how much could it be to replace it? 91, burb, 350.
    thanx
    Skyrocco 16v
  2. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Pretty cheap! About 15 bucks I think. Then again, it could be the gauge, or a loose connector at the sensor or behind the dash.
  3. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    The temp sensor should be on the drivers side above the plug's
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    before you get a new sending unit you can unplug the connector and ground it to ground, it the temp gague maxes out you know its the sender if not your problem lies else were, and if it is the gague in the dash that is not working the sender in the intake is the wrong one, that one is for the computer to measure tempature
  5. rwright07
    rwright07 1/2 ton status
    Jul 30, 2005
    536
    corporate hobo
    my temp gauge stoped workin about a week ago
    same Q' different truck
    76 k5 w/ 400
    thnks
