No torque!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BillyBob, Jun 27, 2001.
  1. BillyBob
    BillyBob 1/2 ton status
    Feb 23, 2000
    557
    Dumont, NJ
    Well, I finally got my 84 on the road today. Wow, it feels a lot different than my 87. But, the main problem I noticed was that the thing doesn't have as much torque as my 87! It feels more like a car. The engine is a GM crate 350, Q-jet, 31" tires, Gearing is "standard" I haven't put many mods on it. Just a Summit Max flow open air cleaner and a set of JBA headers. I just find it weird that my bone stock 87 (okay, so it has a stock performance chip.. but still...) 350 has more torque than it. What the heck is going on?
    <A target="_blank" HREF=http://billybob87k5.50megs.com>Homepage of Porky & Stinky</A>
    Billybob, the REAL <font color=red>Bionic Redneck</font color=red>
  2. 89Blazin
    89Blazin 1/2 ton status
    Mar 20, 2001
    134
    midwest KC area
    Difference in gearing or tranny or both between the 84 and 87 probably.....
    85 Burb and an 89 Blazer
    One just for fun, one simply for pleazer
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It depends on which "crate" engine was installed. The bottom feeder "TargetMaster" engine is a stock replacement. Low HP and torque. You have to spend considerably more money to get one of the performance crate engines.
    Also check the axle ratio. If it has 3.08's it will be a dawg... [​IMG]
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I would agree with the others, could be gearing, trans gearing or low output crate motor
    '83 GMC Jimmy 4x4 ZZ4 Crate Motor
    '83 Chevy P/U 4x4 Sand Drag Racer, 578 RWHP
    '94 Impala SS
    '01 Chevy 2500HD w/8.1L & Allison Auto
  5. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    Well, both have 700 R4 trannies, I still have to pop the cover to see the gearing. And even if the engine was low HP, my 87's is also low. And it has 3.73s and 33" tires. would 3.08s and 31"s feel a lot slower? I guess I should go to a lower gearing?
  6. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Also your '87 is prolly fuel injection. I would think 3.08's would feel slower. The 700R4 in '87 was a better tranny than the early 700's that your '84 would have. I think....
    <font color=blue>I've got a mind like a . . . a . . . what's that thing called?</font color=blue>
  7. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Let's see if I can explain a little algerbra for you.
    (3.73)(X)=(33)(3.08)
    slove for X
    X=27.....
    So 33 and 3.73 is like 27 and 3.08
    So 31 and 3.08 is like 37.5 and 3.73
    Get out your cacul and give it a try !
  8. redbeast
    redbeast Registered Member
    Dec 23, 2000
    67
    San Marcos Texas
    What did he say!!!!!!!! I dont need no stinking calculator !! I got stinking toes to count on!!!!! LOL
    1985 Blazer, 305 soon to be a TBI 350, 700r4, msd ign, 3.43s, headers, 31x10.50x15s
  9. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>It's that 2" exhaust you have on there. You need to get a cat-back made. It wont be as much as your y-pipe was to make. A carb and intake like mine would also help.</font color=blue>
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Standard ratio in '84 was not 3.08, standard was 2.73. That's why she's such a dog. My truck came with 2.73s. It's happy with 4.10s now.
    Tim
  11. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Depending on how long your rig sat between engines, check your cat converter. Sounds a bit off but mine caused me a whole world of confusion because it sat for 2 days during the swap. It seems things cooled and congealed and plugged the converter just enough to build up back pressure so the motor couldn't breath properly. The result, similiar symptoms to what you describe.
    Shawnboy.
  12. BillyBob
    Feb 23, 2000
    557
    Dumont, NJ
    Chris- the exaust is the same as the 87's, except for the blown out muffler. And I doubt going from a Q-jet to a edelbrock 650cfm carb would help me.
    Tim- you sure it's 2.73? That would explain a lot.
    Shawn- I don't think it's the cat. it looks somewhat new. It's obviously a replacement.
    Anyway, since we're talking about gearing, the code for it should be stamped on the diff, right? Where on the diff is it located? We found it on my 87's 12 bolt when we were looking a few months ago, but can't seem to find it on the 84's 10 bolt.
    <P ID="edit"><FONT SIZE=-1>Edited by BillyBob on 06/28/01 08:07 AM (server time).</FONT></P>
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I am undoubtably correct. My glovebox said something to the effect of, "Rear axle ratio--Standard ratio" and it was 2.73. I'm not the only one either. Someone on another site (Chevytalk) has all the option codes for 1984, and it also shows it. Yes, I'm absolutely sure, if you've got the standard ratio, you've got 2.73s.
    In 1984 you could get 2.73, 3.08, 3.23, 3.42, 3.73, or 4.10 in 1/2 ton trucks. Given the choice back then, I'd have only chosen from 3.73 or 4.10 since I run big tires. Stock tires 3.42. I wouldn't even consider higher gearing than that. It tends to have a worse effect on gas mileage if it gets higher than that.
    Ever notice that nowadays, trucks only come with 3.42s, 3.73s, or 4.10s? Most only come with either 3.73s or 4.10s, even 1/2 tons! It took so long for GM to learn!! Too high is just as bad for gas mileage as too low!
    Tim
