NO TURN SIGNALS
Discussion in 'The Garage' started by big k5, Dec 21, 2003.
  1. big k5
    big k5 Registered Member
    Nov 19, 2003
    88
    Sautee Nacoochee,Georgia
    Please help my 84 k5 has lost it's turn signals.I have checked the obvious fuses,turn signal (relay ?) that plugs into the fuse box.I'm not sure where to look next.It has that turn signal switch with the wipers,cruise control ect. on it. I don't know if it makes a difference but my 4 ways do work. I'm tired of using hand signals,because i don't think people know what they are nowdays.
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    More then likely it is the turn signal switch..(plastic thing in column that the turn signal lever attaches to..) they are easy to change ...Good luck
  3. Curtis2kul
    Curtis2kul Registered Member
    Oct 15, 2002
    62
    Winston-Salem, North Carolina, United States
    I have a 84' to so its the same. does the 4-ways work? if not try replacing the flasher (a couple dollars at autozone) if you know it isnt that, look in the column like no smog said, but when you take the steering wheel off there is a lock plate back there, go get a lock plate remover (autozone agian) DONT TRY TO PRY IT OFF it will bend the plate. if you use the tool it will only take a few seconds, once you get in the column you can tell how things work. Good Luck /forums/images/graemlins/k5.gif
  4. Grim-Reaper
    7,385
    Atlanta
    The lock plate remover is a loaner tool from Autozone.
  5. big k5
    Nov 19, 2003
    88
    thanks guys for the replies.i'll definitly check out the turn signal switch as soon as i can find the time.
