nobody has installed poly bushing in a lift kit & paid attention to torque?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Apr 25, 2002.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    come on guys I know somebody knows the answer to this!
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=391563&amp;page=1&amp;view=collapsed&amp;sb=5&amp;o=0&amp;fpart=>link to original post</a>
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Jeff, I never used a torque wrench on mine. I'd guess I torqued them to about 40-50 lbs though. I used locking nuts too...
    Rene
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Make sure they're tight.....really tight.
  4. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    i have been told that you do not want to get them real tight because it might limit travel and wear the bushing out faster.on my truck i tightend my down so that you could turn the bolt head with a little pressure probly around 25-35 flb.hope this helps
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks for the info guys - I kinda suspected that if I torqued these as tight as the book on the factory bushings I'd be WAY to tight.
    I think I'll try 35-40 (if not a little less) with some good lock tight (probably blue).
  6. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    On rubber, I torque them pretty tight, since nothing is supposed to slide anway. With poly, I leave them loose enough that I can spin the bolt with a box wrench without too much force. Then I set a second nut on the bolt as a jamb nut and tighten that one to the first on really good. It seems that most poly bushings are wider than the sleeves inside them, so for the spring to flex, the outsides of the bushings have to slide on the inside edges of the shackles
    Unfortunately, All the grease and care and everything hardly helps anything since I have Rough Country springs /forums/images/icons/smile.gif
  7. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I like the idea of that double nut! sounds like a really good idea, and I think you are right on how to set these so they will flex.
  8. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Tighten them as tight as was posted in that other post (100 &amp; 115). The bushings are suposed to rotate around the sleeve (not the sleeve around the bolt). If you don't tighten them enough it will oval out the hole. If you think they are too loose you could make a longer sleeve.
  9. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    They're supposed to be torqued to 50 to 55lb.
    I think 100 to 110 will make the poly bulge out, which you don't want.
    Boss
  10. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    60 lb/ft. That's what I was told by some guy at an off road design shop in Colorado............/forums/images/icons/smile.gif
  11. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I'm kinda surprised there are soooooo many different answers to this question. I posted this in the ORD section - wish Stephen would drop buy to settle this once &amp; for all.
    getting move obvious why the first post was ignored.
  12. BurbinOR
    5,829
    Oregon
    Um, my answer was from the man himself.
  13. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    The spr9ng eye bushings are sleeved, right?
    So, your not really torqueing the bushings down, your torqueing down the sleeve. (the sleeve -should- be slightly wider than the bushing)
    What-ever it takes to keep the sleeve inplace, you do not want the sleeve to rotate or move (front to back} at-all. It might take 70 ft.lbs, might be 100, doesn't matter. The bolt is strong enough to take the torque, the sleave is "pinched" in place, and the bushing should be lubricated, so torque it to what ever you think. (It would be better to over-tighten it than under)
    I'd put your attation to more important details. Like makeing sure the suspension is neutral, -before- tightening. (jounce/bounce the front suspension to make sure every thing is torqued at it's ride-height)
  14. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    thanks Eric...
    actually I have never retorqued this suspenion, and that is exactly why I put this post up. I was planning to loosen all the bolts, bounce it, and then torque it down.
  15. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I dunno about what is supposed to move on what here.
    It sure looks to me as if the sleeve and bolt do the movement and the bushings remain still.
    I am with the super loose and double nutted theory.
  16. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Fair enough,
    I don't think a guy would want the sleeve moveing around at-all.
    Stoping a 5000 lbs truck, repetedly - is alot of force directly on the front spring eye (70-80 % of the brakeing force is done with the front brakes), This force, I would think, might oblong the bolt hole if the bolt torque was insufficiant, and allowed the sleave to move/slide back and fourtth.
    I think Stephen said it was 50 or 60 ft/lbs (?) .
  17. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I'm with you on this...if I wanted the bushings to rotate easier I would make a sleeve just a bit longer than stock and tighten it down real good.
