NOID light pulses
Discussion in 'The Garage' started by Hossbaby50, Dec 23, 2003.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I am diagnosing TPI issues:
    I have a question about testing the module.
    The test is to put a 12V power to the purple (refence) wire for the injectors at the distributor and when 12V is removed the NOID light should blink.
    Mine does blink, but VERY little. You can barely see the filament of the bulb turn red and then go away. Is this how it should work or should the bulb really flash.
    Sometimes when I accidentally touch the reference wire a couple times quickly the light flashes bright, but it is very dull if I only touch it once.
  2. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    do u mean tbi? I know on TBI they should be very bright, the brighter it is flashing. At night it should light up underhood pretty well. I was having starting issues and it was a barly visible pop, then once i fixed it if was one bright sunavagun.
  3. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Nope, I mean TPI. I am swapping it in right now.
    My flashes are very dim.
  4. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    hmnnnn i can only assume that they too would need to be very bright.
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've never tried one out on my TPI setup. But since TPI is doing with 8 injectors what TBI does with 2, then it would stand to reason that the pulse width to the TPI injectors is about 1/4 of that required for the TBI injectors, to deliver the same amount of fuel. So yeah, the pulses could be pretty short. Does the noid light flash continuously while cranking the starter? If so, then the injectors should be squirting some fuel into the engine. If not, you need to figure out why... ( <-- From my mastery of the obvious! ) /forums/images/graemlins/wink.gif
  6. dyeager535
    26,978
    Perhaps an analog voltmeter would work best? I know in short duration events, the analog works better than digital stuff, I'm betting a light would act the same as the digital voltmeter with extremely short duration pulses.(?)
  7. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    Hmm, I got to thinking about this some more. Since each of the TPI injectors is rated to flow a lot less than the TBI injectors, perhaps the pusle widths aren't much different between them. /forums/images/graemlins/eek.gif
