Noise and vibration coming from front end ? UPDATED
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TxK5Blazer, May 8, 2003.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    When I brake I have a popping kind of noise coming from front end. I also have a vibration while driving at hwy speeds. The vibration is in the stearing wheel so I assume it is in the front end. Could the cause of both these problems be from the same thing? All Help will be appreciated......Jason
    I assumed the noise was coming from the front end with the steering wheel vibrating well Saturday I slung the rear drive shaft at 65mph Not sure why the u joints in there were a month old. Does the rear axle have keepers on the yoke where there u joint sits? If so mine doesn't so when I put the new ujoints in and the new straps and bolts cause the other ones got real *#@!%^$ up if you know what I mean. I put the little keepers on the u joint this time and torqued them down so lets see if they hold this time Oh and vibration is gone....Strange thing ......Jason
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    Re: Noise and vibration coming from front end ?
    how are your front bearings? sounds like a rotational problem, ie something that moves around, bearings, brakes, axles etc, id say start pokin around pull the wheels and check out the brakes and the bearings, make sure the springs are tight..? just my .02
  3. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    Check to make sure all of your lugs are tight and are seated properly. Could have a bent wheel that keeps vibrating the lug nuts loose.
  4. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    all is tight posted a update
