noise bad when i turn
Discussion in 'The Garage' started by bryguy00b, May 31, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    i get this noise now usually when im turning kind of a rotating type noise..not really clunky but..a loose sounding type thing. its really hard to wright. could it be u-joints? i shaked all of them and they are all tight..i can only think wheel bearings or joints..
  2. landsmasher
    landsmasher 1/2 ton status
    Mar 13, 2002
    4,423
    California, The Blow Me State
    If it happens ONLY in 4wd it's an axle shaft U joint. If it happens in both 4wd and 2wd it's most likely a bearing.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea those things sound horibble there getting worse if it would quite rainig around here for once im ganna take a look at them...
  4. Grim-Reaper
    7,385
    Atlanta
    Pull the locking hubs off and see if you got water in there. Could be a front wheel bearing going out.
  5. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea..what i plan to do in the next couple days..wouldnt surprise me any..
