Noise Capacitor ?? Do you have 1 ??
Discussion in 'The Garage' started by mudslinger99, Jun 8, 2005.
  1. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
  2. PhoenixZorn
    PhoenixZorn 1/2 ton status
    Mar 17, 2005
    1,734
    West Allis, WI
    I don''t feel like going through all the cookie crap on that site again, so without looking at it, I'll just mention that I have one in my car, and it works... you can also skip the thing altogether and pickup static reducing spark plug wires, which will pretty much do the same thing as the capacitor to a lesser degree. Unless you run in SPL competitons and Bass comps, you don't need one unless you already hear the static from your engine through your speakers...
  3. mudslinger99
    Oct 8, 2004
    512
    East Coast
    Is yours the type that plugs in to the altenator ?...
    I know somebody else around here has got 1 or tried 1 before...
  4. tunedportk5
    tunedportk5 1/2 ton status
    Jul 13, 2004
    371
    Union City, CA
    If you don't have one then it's worth the try
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Usually they're noise suppression coils... capacitors don't let current flow too well on DC.
    GM used factory coils on many things. The most common are on the blower motor.
    I'd put one inline with your CB or radio's power lead. The alternator rarely puts out enough RF to affect anything. I'm willing to bet your problem is ignition related. Usually a fresh power supply off the battery will eliminate it.
  6. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Uh, coils in series, caps in shunt. If it's grounded on one end, it has to be a capacitor, an inductor would create a short. It's true that capacitors block DC, that's the point. It passes the AC that's riding your DC voltage (the whine) to a ground without passing the DC, because passing the DC to ground would short it out.
    Are you talking about the resistors? That's a whole different story, used as resistance to create different motor speeds, not as an inductor to filter frequencies.
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The problem with using a capacitor for noise suppression is that it is a limited bandstop filter. It does work though. Usually you'll see a capacitor and a coil... or just a coil. Not very often do you see just a capacitor in an automotive application.
    I'm talking about the coils you see on just about every blower motor from the 70s and late 80s/early 90s. The coils of resistance wire for blower speed stuck in the blower housing is something completely different.
