Noise from the steering box
Discussion in 'The Garage' started by MilpitasK5, Nov 27, 2003.
  1. MilpitasK5
    MilpitasK5 1/2 ton status
    Nov 13, 2001
    889
    Milpitas, Ca.
    My steering box has a noise coming from it. Sounds like it's creeking when the steering wheel is being turned.
    I checked the fluid and topped it off and also greased all the steering components.
    What kind of trouble is this? I'm picking up another steering box soon but is this problem serious?
    TIA
  2. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    creaking noise from the box?? is the box loose or frame cracked?
  3. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    The box doesn't look loose when the wheel is turning and I installed the weld on brace so that should be cool too. /forums/images/graemlins/thinking.gif
  4. Confedneck
    Nov 1, 2002
    5,236
    im not sure how these boxes go together, but it sounds like you could have a worn bushing/bearing in the box causing the noise, is it coming directly from the box? or maybe from the joint on the steering arm?
  5. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I'm thinking from the box b/c when I put my hand on it while it's turning, it feels like the noise and a little vibration (I can feel) is the same. Not for certain though. My drag link and the ball joint boots are lookin' pretty worn.
    Hopefully it'll hold up! /forums/images/graemlins/crazy.gif
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    is it hydraulic noise or mechanical metal to metal sound ?
  7. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    I think it's mechanical. Well, kinda like when you pull an old nail out of wood really slowly... /forums/images/graemlins/crazy.gif
    Or the sound of an old house making a creeking noise when people walk on old floor boards...
    Sorry for the terrible description! /forums/images/graemlins/rolleyes.gif
  8. Confedneck
    Nov 1, 2002
    5,236
    have you tried bleeding air out of the system? ie lid off resevoir, turn slowly lock to lock holding at each lock for 10 seconds, repeat 5 or 6 times?
  9. MilpitasK5
    Nov 13, 2001
    889
    Milpitas, Ca.
    No, haven't tried that. maybe I'll do that right now. Thanks.
  10. motormayhem
    motormayhem Registered Member
    Nov 8, 2008
    10
    earth
    What was the fix? Mine is doing the same thing. Pretty sure it's not a cracked frame.
  11. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Holy smokes batman, talk about digging up an old post. Chris has been long gone for a long time now.
