noise i cant find need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JDELBLAZ, Mar 14, 2000.
  1. JDELBLAZ
    JDELBLAZ 1/2 ton status
    140
    STAMFORD C.T
    THIS NOISE IM GETTING HAS STUMPED ME IT SOUND LIKE THE REAR AXLE BUT NOT SURE WHEN I TURN A CORNER I GET A CLUNCK WHEN I STOP CLUNCK WHEN I GO CLUNCK THE BLAZER HAS A 6"LIFT AND A 10 BOLT AXLE (I KNOW NOT A GOOD AXLE) 35" TIRES AND A HOST OF OTHER GOODIES AXLE DOES NOT SEEM BAD AND SPRING ARE TIGHT WHAT COULD IT BE
  2. 79Cheyenne
    79Cheyenne 1/2 ton status
    Feb 19, 2000
    116
    Atlanta,GA
    did you look at your universal joints yet?
    they clunk when they go bad, and they're a cheap fix...
    <font color=orange>1979 BLAZER Cheyenne[​IMG]
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Another place to look is the carrier in your diff.
  4. 1bad2
    1bad2 Registered Member
    65
    Jacksonville, FL
    I'm not 100% sure but the newer trucks, tahoes, and suburbans have a slip yoke that when not greased causes a bump like you are describing when starting and stoping. You might try removing your driveshaft and puting some high temp grease in the spline area of your slip yoke.
    Curtis
  5. 3030
    3030 Registered Member
    Feb 18, 2000
    14
    Sulphur Springs, Tx.
    Have the same problem with my 80 k5. Found out I need A new rear end, just don't have the funds to get her fixed now.
    There ain't no way I'll get stuck in that hole.....oops.
  6. Zack
    Zack 1/2 ton status
    Feb 18, 2000
    329
    IL, USA
    hey what gear ratio do you have in the rear end you need to replace? i might have one for ya. I live in Illinois
    Zack
    No I am still not done with my frame up resto!! Soon i swear!
  7. DangerB
    DangerB 1/2 ton status
    420
    Frisco, TX.
    Ive got a 12 bolt 3.73 for sale in Dallas.
    DangerBrett[​IMG]
    <font color=blue>life is a race, you have to look good and go fast!</font color=blue>
