  1. ducati-cooter
    ducati-cooter Registered Member
    Jan 24, 2002
    78
    Madison WI
    I have a 90 k5 350/700-r4 10bolt front and rear open both, and running crappy 31 in tires. At least once or twice a day while driving I here and feel this growl like I am running over a rumble strip but I am no were near one. PLEASE HELP !!!!!!!
    Thanks for any help in advance.
  2. Tuff84blaze
    Tuff84blaze 1/2 ton status
    May 12, 2000
    119
    Liberty Lake, Washington
    Mine does this too, but only when I let off the gas at any speed above 45mph. It is something to do with the slip yoke and my lift. I've put 10,000 miles on it this way and just live with it because i don't have money for a slip yoke eliminater kit. I just apply the brake before letting off the gas and the growl goes away.
  3. blazentank
    blazentank 1/2 ton status
    Apr 18, 2001
    426
    Houston, Texas
    Mine dose it when i let of the gas too but only above 50mph. I get alot of vibrations and grinding in my feet and seats and i can hear grinding sound too. it goes away when i apply the brake too. weird i wonder what it is
  4. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Is yours lifted at all? Mine does the same thing when I let off the gas over about 25mph. I just have to power brake it to a stop. I have a shackle flip and 1 1/2'' blocks on the rear with the stock drive shaft. To fix the problem on most lifted K5's you dont necesarily have to get a slip yoke eliminator, most of the time a c/v rear shaft will do the trick.
  5. ducati-cooter
    Jan 24, 2002
    78
    Madison WI
    i don't have any lift the only thing not stock is the tires
  6. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    IMO you need to have your transmission checked. I had an identical situation in a Suburban once and it turned out to be the torque converter.
  7. Mr. Jimmy
    Mr. Jimmy Registered Member
    Mar 14, 2002
    63
    Haynesville Ga.
    I also have an 89 Jimmy with a 6 inch lift that does the same thing above 50 mph. Has anyone tried a rear CV shaft without the Slip yoke eliminator and had good results? Where is a good place for purchasing these?
  8. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    How are your u joints?
