NOISE
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DMK, Jul 18, 2000.
  1. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Have noise coming from the rear end I think. Noise only happens when rear tires slip. It is a ratcheting noise, only last for a few seconds. Truck is an 87 k-5 with limited slip rear end has 35,000 on it. Fluid has not been changed yet. Could this be the cause? Thanks for any help.
    What would cause this?
  2. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I don't know the cause but you should change the fluid every 10K or so.
    90K5
  3. Scoobydoo
    Scoobydoo 1/2 ton status
    Jun 9, 2000
    244
    Phoenix / Peoria ARIZONA. (75thAve/DeerValley)
    Check all your suspension hardware (u-bolts, shocks, shackles etc...) you may just have some loose nuts and/or bolts back there. If that all checks out you should probably pull the rear diff cover and see "wuz up"? in there. Incidentally where as it may be stated in a shop manual somewhere to change your diff fluid every 10K?, I really don't know of anyone who does that. If you go through alot of Mud and Water you should change it shortly after, but otherwise I would think every 30K should be OK. My dad had several company trucks with well over 100K on them and none of them ever had the diff fluid changed.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I think I saw somewhere where you are supposed to change it that often if you go through mud a lot but I dont change mine that much either
    90K5
  5. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  6. Kelboski
    Kelboski 1/2 ton status
    306
    Mcdonough,Ga
    change the fluid, and put new GM additive for the limited slip if thats what it is.......my 2 cents, hope it helps
