noisey 10 bolt
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrapper, Mar 28, 2001.
  1. scrapper
    scrapper Registered Member
    Jun 12, 2000
    33
    Wisconsin
    My 10 bolt has a high pitched noise that is only detected at higher speeds under load.I would guess that the pinion shaft bearings are the cause.I had the diff cover off awhile back and found nothing that would cause the noise in either the ring gear or axle bearings.The pinion saft was not loose either.Is ther any good sources to purchase a bearing kit for these axles(85 corp 10 bolt/w gov lock 3.73).
  2. dyeager535
    26,978
    http://www.dorianyeager.com/index2.html
