Noisy lifter
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Whii338, May 13, 2000.
  1. Whii338
    Whii338 Registered Member
    Apr 24, 2000
    35
    Anybody got any ideas on how to quiet noisy lifer?Already tried some engine flush then changed the oil..stayed quiet about 30 min. then started rightback up...its a 88'k5 350FI with 164,000(i guess i should be happy its just a lifter!)
  2. Black89k5
    Black89k5 Registered Member
    Mar 12, 2000
    42
    Are u sure it's a lifter??? Cause mine did the same thing and i tightened down the rockers and it was fine.
  3. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Put a can of Marvel Mystery Oil in your oil, and those engine flush products are usually more harm than good on a older engine. They loosen chunks of carbon and plug up your oil pump screen. Matt
    Displacement, cubes, and did you say you drive a riceburner???
  4. Oil Man
    Oil Man Registered Member
    Apr 25, 2000
    27
    Santa Clarita, CA USA
    First like the other guy said try and see if your rocker arm is loose. Then If you try a thin oil like 5-30 and you don't see any improvement then you just have a lifter that is weak, and will have to be changed. But if by using a thin oil it gets better then you have some deposits that should be cleaned out. Let us know what you find out.
    Sincerely, Kevin
  5. Grim-Reaper
    7,385
    Atlanta
    Adjusting the lifters no big deal. Why not try that and see if you find a loose one. Its explained in Haynes shop manuals and only takes a couple of hours.
    Diging it in the dirt with my K5's
    Grim-Reaper
  6. bart
    bart Registered Member
    Mar 15, 2000
    69
    Eastern PA
    yeah...try the rocker pivot nut...check your service manual...but the valves on the cylinder that you are tightening should be closed (spring fully extended)...spin the pushrod with your fingers and slowly tighten the rocker nut until you feel resistance against rotating the pushrod...then tighten 3/4 to 1 1/4 turns more. This might help...I had a lifter that wasn't pumping oil very well...this took care of it..
    good luck.
