non 4x4 fabrication question
Discussion in 'The Lounge' started by bad_bo_ti, Nov 11, 2003.
  1. bad_bo_ti
    bad_bo_ti 1/2 ton status
    1,027
    OhiO
    i was wondering what is the best way to make a piano hinge. i have some steps in my pole barn i was wanting to beable to hinge up when i didnt use them, they are made out of 2x10 and are approxiamtely 6.5-7ft tall and have about 10 8in stair treads, the width of the stairs are 30 in, so the hinge would need to be 30in, what kind of thickness of metal should i use, i am also open for other hinging ideas! thanks, chris
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    My dad did something similar in his barn. He took some standard 8" - 10" door hinges and welded them to some 1/4" plate. Its been there for close to 20yrs so far. He also used lag bolts to hold it in place /forums/images/graemlins/thumb.gif
    The hinges he used actually looked very similar to this:
  3. bad_bo_ti
    1,027
    OhiO
    thanks never thought of that, did he use a pulley system to lift them up with, thats the route i am going to go.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Yeah, he just hung a small snatch-block from the rafters with a rope to raise and lower it. Just keeps the rope tied off to the barn pole.
    His barn is 80 x 160 with 12 x 160 wings on each side(main section with a 80 x 140 loft)with an attached arena which is 80 x 120 /forums/images/graemlins/eek.gif
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
  6. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    sorry to hijack but
    God that would be a hella of a shop.
  7. 350350
    350350 1/2 ton status
    Sep 25, 2003
    939
    USA
    Back when I had the 'Old Homestead', I had a big old Dairy Barn with a big loft. I built a ramp similar to the stairs you're talking about. I used the ramp so I could park the mower, 4-wheeler, motorcycles, etc., in the loft and leave room for more junk cars below... /forums/images/graemlins/1zhelp.gif
    I used 2x10's and bored a 2" hole in the 'loft' end. I then made supports off the side of the loft wide enough the ramp would fit between them and bored a 2" hole in them too. I used a piece of 2" pipe to run through all 4 holes and support the high end of the ramp. That way it was free to pivot on the pipe and was strong enough to support the weight of my 1967 John Deere riding mower... /forums/images/graemlins/eek.gif
    Then I rigged up a pulley system similar to what's described above to lift the ramp out of the way.
    That was over 15 years ago and my Step Brother lives there and still uses it as far as I know.
    Paul 'X' /forums/images/graemlins/thinking.gif
  8. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Paul, a 2" pipe is actually 2.375" OD... Must have been a 1.5" pipe in your pivot (1.90" OD) /forums/images/graemlins/thumb.gif
  9. 350350
    Sep 25, 2003
    939
    USA
    Yeah, what he said! /forums/images/graemlins/grin.gif
  10. bad_bo_ti
    1,027
    OhiO
    thanks for all the help, if i was planning on making my own piano/continuous hinge, how thick of metal should i use for the flat part and for the tubing? thanks, chris
  11. 350350
    Sep 25, 2003
    939
    USA
    In the spirit of over-doing everything, I'd say a couple of things:
    /forums/images/graemlins/tongue.gif If you were to do the math, I would bet that a 3/8" or 1/2" rod would be more than strong enough to support the stairs, and therefore you could use a piece of 1/2" rod with and a pipe sized to fit over it. (Lil' help here on pipe sizes again?)
    /forums/images/graemlins/tongue.gif On the other hand, If you used a piece of 1" pipe as the center of the hinge and a larger pipe to go over it, then used 1/8" steel for the wings of the hinges, you could probably grease it on assembly and not have to worry about it again for 100 years or so.
    /forums/images/graemlins/tongue.gif Or, I'd also bet that if you went to a local Farm Store and bought the biggest barn door hinges they have, they would also last a good 100 years.
  12. bad_bo_ti
    1,027
    OhiO
    yes i am a strong believer in overkill!! /forums/images/graemlins/thumb.gif i was thinking maybe 1/4 or 3/8 plate and then a 1/2 solid rod to go into a 1 inch (1/4 wall, 1/2 i.d.) round tube, i do know there is a difference in tube and pipe, as long as i use tube then i will be alright with my figuring!! /forums/images/graemlins/rotfl.gif i am gonna check at a farm store for some hinges, if i fab something up maybe i will post pics for anyone else in the future!!! /forums/images/graemlins/grin.gif
    chris
