non chevy question about vibrating minivan
Discussion in 'The Garage' started by google, Jun 9, 2005.
  1. google
    google 1/2 ton status
    May 19, 2005
    805
    Arizona
    This is a dodge caravan question. My family 95 caravan shakes A LOT between 40 and 45 mph. Enough that my wife won't drive it anymore. Works fine through 1st, 3rd, 4th gear (AUTO TRANNY), but when it get's to 40mph in seconed gear it starts to shake the whole van until about 45-48mph. The tranny was rebuilt about a year ago and we haven't had any problems. Any clues???
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    CVs they are polly worn
  3. dunehopper502
    dunehopper502 Registered Member
    Mar 1, 2004
    56
    MI, U.S.A.
    when you are in second and vehicle starts to shake throw the tranny into neutral and see if it still shakes that'll tell you if its tranny related if not my guess check cv shafts,motor/trans mounts,TIRES....
  4. 79chevyk10
    79chevyk10 1/2 ton status
    Dec 14, 2003
    612
    Central Coast
    If it shakes more when you're on the throttle, Its the CV shaft/Half shaft's inner tri-pod joint. Get a reman unit for 65 bucks probably. Just gotta fine which one out of the two.
  5. google
    May 19, 2005
    805
    Arizona
    That's it then I THINK... I don't know what those parts are though. If I look in my blazer chiltons, would I be able to find something similer to look for?
  6. 79chevyk10
    Dec 14, 2003
    612
    Central Coast
    They are the axle shafts with rubber boots on them that go from the transaxle(transmission) to the wheels.
  7. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    Plain and simple the answer is NO... Your blazer has a completly different front end then your mini van has...
  8. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I'd say tires.
