non-CV front driveshaft?
Discussion in 'The Garage' started by TX Mudder, Mar 12, 2003.
  1. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I am considering running a front driveshaft without a CV.
    I already have 1350 yokes for my 205 and front axle.
    I wanted to run a CV front but it simply does not exist for a yoke output like my 76 NP205 front.
    So............what is the harm in running non CV? I did some searching and the 1350 ujoint is good for 20 degrees. I haven't measured my angles yet but will soon.
    What do you guys think?
    BTW, here's the chart I found the ujoint angle stuff in:
    My thoughts:
    My 205/465 is 10 spline and that is the weak link for sure. However, I just don't like have a wimpy 1310 front driveshaft. SInce the 1350 CV is not an option for me because I have a front yoke and not a front flange, a normal 1350 would be good because I already have yokes for both the 205 and the 60.
    -- Mike
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    There are CV joints out there that don't require a flange for mounting. They bolt right to the yoke. I've got one in the garage. Check with a driveline shop for more info. /forums/images/graemlins/cool.gif
  3. Super_S
    Super_S Registered Member
    Jul 30, 2002
    11
    Katy TX (west Houston)
    I don't run a CV on my front. It is because I am running 12"s of lift and there isn't a CV that will handle the angle my truck has (damn 205/th350 combo). I run a 1310 at the axle and a 3R at the case (for now, until I upgrade it to 32 spline). It may vibrate a little at high speeds so try to stay off the highway in 2wd high.
  4. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    OK, so I'm reading closer and see that you want to go with a 1350 CV. /forums/images/graemlins/shocked.gif The one I've got is an old stocker.
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Get the output and flange from a Ford or Dodge 205. Many are 32 spline and accept the heavier CVs. I'm told to look specifically for divorce mounted cases too. I'm currently looking for the same.
  6. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I had one in my Jimmy for a while but it would rub on my Xmember so I took it out. It is HEAVY duty and sitting in the corner of my garage.
  7. TX Mudder
    Jul 10, 2000
    2,514
    Houston
    sent you a PM
