non-emissions 6.2L wire harness
Discussion in 'Parts & Trucks Wanted' started by yunit, Oct 5, 2005.
  1. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    Oakland, NJ
    Looking for a non-emissions 6.2L wire harness, inside and out. Thanks.
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    Stevens Pass Highway, WA
    Almost all of the diesel wiring is the same as the gas version... everything diesel specific is just add on wiring that is in a seperate harness from the main one. If your converting a gas rig to diesel the only wire I had to change on my '79 K10 was the HEI ignition wire needed to be extended to the front of the 6.2L. Then I added the glowplug wiring harness from a donor truck (but modified it for manual operation). Alternator, oil pressure, and temp sensors are all in the same locations between a SBC and a 6.2L.
