Non existant steering column brace/bracket
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by mastercraftkpk, Apr 13, 2003.
  1. mastercraftkpk
    mastercraftkpk 1/2 ton status
    Mar 12, 2003
    192
    Houston, TX
    I just pulled the body lift off of the 72 that I very recently acquired and the steering column wanders all over the place.
    It looks as though the nucklehead who put on the body lift tossed out the bracket that mounts onto the inside of the firewall that secures the column.
    Does anyone have any ideas re: replacement.
    I have already searched all of the junkyards around here. Finding any pre-73 GMC trucks is next to impossible.
    Does anyone have a source for aftermarket? I have already looked through the LMC, Chevyduty, and Brother's catalogs.
    Maybe I'll have to fabricate?
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    pm me as i might be able to help ya but a pic would help a lot
    Randy
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i dont know where you could get one but it looks pretty simple to make one.all it is is a flat plate with 2 bolt holes that bolt to the fire wall.then there is a 90 degree bend where the bracket hits the steering collum and is held in place with a clamp similer to a exhaust clamp.all of the trucks around here are crushed if they are older than '80 so not much left out here to get a oem piece.there is a yard out in jersey that i found that still has a few 65 to 72 trucks but are mostly picked clean already.if you need a pic of what it looks like let me know.
  4. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    I'd ask over on 67-72chevytrucks.com. I'm sure it is the same bracket in the trucks. There are several used part vendors over there too.
  5. mastercraftkpk
    Mar 12, 2003
    192
    Houston, TX
    Thanks everyone. I actually pulled a similar part off of a 70 Ford pickup today it looks like it will work with a little trimming.
