non roller cam to roller cam?
Discussion in 'The Garage' started by 2High4U, Oct 23, 2005.
  1. 2High4U
    2High4U 1/2 ton status
    Aug 20, 2005
    542
    Felton Pennsylvania
    if i had a motor with a non roller cam could i change the cam to a roller cam if i can what else would i need to change (lifters etc?) the motor i have says it fits 87-95 will it work in my 73 because they all bolt up the same whats the difference?
  2. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    It would help to know which motor your talking about here.
    I could be wrong, but you cannot just slap a roller cam in a non-roller block. You need to buy a "retro roller" kit. Most the cam companies sell retro-roller kits to fit a roller cam into a non-roller block. You must change the lifters, they are part of the whole roller system (probably the main feature), they need to be the roller type. The kits come with everything you need. They are pricy though, cam/lifter/chain kit for my 4.3lV6 was $189, retro roller kit for same was $580.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    If the block truely is a 87-95 and even if it currently does not have a roller cam the block is almost definately set up to accept a factory hydraulic roller cam.
    If this turns out to be the case you would need
    cam thrust plate and bolts, cam, lifters, lifter cross bars, lifter spider tray, push rods for roller lifters and the correct timing set for a roller cam.
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    before purchasing any of that stuff, you need to pull the intake manifold, and verify that it has the bosses for the lifter spider tray i have seen several 87-90 blocks that didnt have them.
  5. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    If you are going to use a "retrofit" cam, you need to make sure it has the cast iron distributor gear pressed on or you need to run a bronze gear on your distributor. There is also some new space-aged plastic gear for the distributor available.
    Different length pushrods too. Cam button, and new timing chain cover also.
  6. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    alright my final line of questions that concern me... i want to use my flexplate off of my 73 k5 will it mate to the crank on this newer motor? this newer motor I think has a one peice seal would that qualify for another style oil pan or can i just use the same one off of my blazers motor im not sure what kind of heads are on this motor im waiting for the casting number hoping that the vavle covers will fit... the 73 from what i beleive is stock original..
    as for the original question posted i found out that it is too expensive to change and wouldnt benefit me at this time due to lack of horsepower\torque i hear they are only practcal in higher horsepower engines but i hear that it is possible to do with a set of roller rockers springs and other things needed pretty much like the retrofit prolly.
  7. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Nope, flexplate for one-piece rear main seals is weighted so you can't use your old non-weighted flexplate. Uses different pan too.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    bolt pattern on the flexplate is also smaller.
  9. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    any ideas on where to get a cheap oil pan and flexplate? btw thanks a lot this has been very helpful
  10. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Your best bet would be to hold on and go to a large swapmeet in your area, I've scored deals well below the lowest advertised prices I've seen at summit or jegs. If you can't wait you could always go with summit or jegs, or cruise on over to www.thirdgen.org and visit their classified section.
    Good luck.
    stock replacement oilpan at summit: p/n SUM-G3503X $33.99
  11. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    a new flex plate from your local auto parts store should be similar in price, just ask for one for a 89 chevy 1/2 truck for a 168 tooth, a 89 camaro 350 for the 153 tooth
  12. 2High4U
    Aug 20, 2005
    542
    Felton Pennsylvania
    the holes for the stall\torque converter are the same right? i dont want to have to replace that because I replaced the tranny 2 or 3 months ago and its all new speced for a 73 i hope the new style flex plate will bolt up to it.
  13. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
    Found this at summit too: p/n TCI-399 733 $84.88
    Has both the small and large bolt patterns for converter so you'd be o.k. (10.75" and 11.50").
  14. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
