NonGreasable joint q?
Discussion in 'The Garage' started by Hossbaby50, Jul 6, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I picked up a Brute Force joint for my front driveshaft last night to replace the joint in my spare driveshaft.
    The counter guy said it is pregreased and it is nongreasable. I am thinking I still should throw some more grease in the caps just for sh&t and grins though. Should I?
    Counter dude said it was synthetic grease in the joint but all I have is semi synthetic red Valvoline grease or Marine grease (boat trailer wheelbearing grease) Which should i use and is it ok to mix greases?
    I don't run alot of water in Arizona as you could probably guess so I don't think the Marine grease is warranted.
    Harley
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I never bother to put any additional grease in them. They're lubricated for life according to Neapco.
    If you're going to add grease, use the wheel bearing grease as it is made for higher temperatures.
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    on my Spicer 5-806x joint for my D60 shafts, the little piece of paper in the box said to leave them the [darn] alone...so I did. It said not to add any grease...
    Chris
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    what does "for life" mean?
    once it is rusted away its life is over?
    I just pulled a joint out of my new 60 a few days ago and thought of you
    some offbrand greaseable that had a blockage to one cross
    2 rusted and seized caps
    2 in very serviceable condition
    that is now added to my 'trophy collection' for next time someone claims non greaseable are a good idea
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Have it your way.
    Non-greasable are stronger, and sealed better than greasable, that is not a question.
    Spicer makes both types for those that prefer the others. Every decision you make on something to do with your rig involves trade offs. I will not trade off strength for maintenance ability. You apparently will, and that is fine with me if it is fine with you.
  6. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    I use non-greasable joints as well! /forums/images/graemlins/peace.gif
  7. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Well I ended up slapping some Marinc grease in the end of each cap and grease pit. Not because I wanted to but because I had too. Apparently 110* heat doesn't keep the factory synthetic grease thick enough to hold needle bearins in place so I used the Marine grease to hold it. It may not be the way it should be done but oh well, it is much better then the bone dry ujiont that was in my front shaft that I replaced with my spare.
    Now I have to repeat the process again on my other driveshaft. Apparently the madness never ends. /forums/images/graemlins/doah.gif
    Harley
  8. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you still have never shown an instance that the grease passage was the cause of breakage
    and I have never seen a break origonating at the grease nipple
    I can show you countless rusted to death u joints
    I do not think strength is effected, service life is vastly effected
    it isnt like you have enough power to spit out 1480 WJs anyway, same boat as I
    most images of busted ujoints show the bearings dry as dirt and rusted
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    ah hem
    wouldnt a grease nipple be handy?
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am a die hard non-greasable man. You can't fit a grease gun in the corner of a yoke most of the friggin' time any way. I am looking into drilling out each of the caps of my 806's and installing pin style flat mount zerks (like the ones on CTM's). I might try this on all of my joints (probably test on a 1310 cause they are cheap). They will be as strong as before but servicable (a bit easier to do for some joints). Anybody else done this before? Did it work.
  11. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Thought about it a whole bunch of times. It wasnt so much that i like non greasables, just that it was darn near impossible to get a grease gun into the passages- However, someone told me that I can acutally use a grease needle to go right into the grease nipple head, and get grease in there that way. havent tried it yet, might just do it tomorrow....
  12. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I have the needle for my grease gun and there are only 2 spots it won't reach , 10 bolt upper ball joints. /forums/images/graemlins/angryfire.gif
    It works awsome for greasing all the rest of the drive train /forums/images/graemlins/thumb.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I threw away the normal grease gun tip after I tried the needle
    with the needle all the grease goes into the part rather then all over the outside of the nipple
    BUT I think the poster was asking about driveline ujoints and you can get a normal grease gun on all of them except the CV where you need a needle
    IIRC the 1480 D60 ujoints SPL55-4x come with the needle style lube points
  14. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Harley
    Welcome to the club buckwheat /forums/images/graemlins/histerical.gif The year before last was my "driveshaft hell year" /forums/images/graemlins/doah.gif
  15. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    If you do this on your driveshaft then you better not drag it across anything and shear the zerks off.
  16. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Maybe that's why Moog uppers have the zerk on the lower side so you can easily reach it. /forums/images/graemlins/thumb.gif
  17. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Spicer 5-806x's are axleshaft ujoints. Not driveshaft ujoints.
    Harley
