Noob 350 sb interchange q
Discussion in 'The Garage' started by gibby2268, Jun 15, 2006.
  1. gibby2268
    gibby2268 1/2 ton status
    Jun 6, 2006
    553
    Middle TN
    Howdy all! Just took on a project (read money pit!) 79 K5 Blazer that I picked up CHEAP. It has an 89 shortblock in it and I have a set of decent 74 heads, Edelbrock torker intake Holley 600 (I think). I've done a good bit of searching but am still a bit unclear, will the older heads go fine on the newer block? Please pardon my ignorance, I've built some engines before but never a Chevy.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yes the heads will bolt on . Just make sure the intake you use is meant for the heads . They changed the angle of the middle intake bolts on the newer stuff .
  3. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    Whats the last 3 casting numbers on your heads? I can tell you how " decent" they are.
  4. gibby2268
    Jun 6, 2006
    553
    Middle TN
    the last 3 are 882. From what I've read these do tend to be "crack prone." Any particular areas I should check as to cracks?
    I know that these are some of the lower powered heads out there, but right now they'll do. VERY tight budget on this thing!
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Those aren't that bad if they have been gone though , as far as 70's era heads go . I have a set all finished and in plastic bags to go in my Chevelle with larger valves and some mild work done . I don't plan on running too fast .
    They outflow the aluminum head mid 80's vette heads :thumb:
  6. gibby2268
    Jun 6, 2006
    553
    Middle TN
    Thnx, Good to hear.
    'Nuther dumb question...the head gasket sets are different for the two different era parts I have....which do I go with? Was gonna go with a Felpro set, but do I use the age of the heads or the block to determine? I'm guessing the heads, but what do I know???:o
    Oh yeah, pretty sure the intake is for an older one, so that shouldnt be a problem.
  7. theperfectgarage
    Oct 5, 2005
    988
    tucson arizona
    Yeah, the 882's are not the best of that era, but you are not building a race car either. Have 'em magnafluxed at the machine shop to check for cracks. Oh yeah, and dont listen to Pauly383, I dont think he has a k5 or even a drivers license.:D :wink1: j/k.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
