noob driveshaft question...
Discussion in 'The Garage' started by mr.smartass, Oct 11, 2006.
  1. mr.smartass
    mr.smartass 1 ton status Premium Member
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    on my 89' blazer 350/700r4 on my front drive shaft there's a little stud that appears to be a broken off grease alimite, just wondering if it's pressed in there or threaded, i just wanna replace it, so i can grease it.
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    its just a greese zerk, they are threaded in there
  3. mr.smartass
    Aug 10, 2004
    10,860
    4
    Hattiesburg, MS
    actually it wasn't threaded... i got it to turn using the ease-out but it just just spun in the hole... so i put it on the drill press and drilled it out, i'll either tap the hole or find a press in one, another question is, is there a seal in the little screw on cap for the yoke on the driveshaft??
