Noob question, year of axle???
Discussion in 'The Garage' started by sapper, Jan 20, 2007.
  1. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    Looking at ordering a gear install kit for my 14FF, how do I tell if its a 88 or older? TIA
  2. goldwing2000
    goldwing2000 Guest
    Distance between the spring perches and design of the brake drums.
    Axles from an IFS truck (88' and up pickups, except crew cab) will have wider spring perches and the drums on the outside of the hub (like a semi-float axle).
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    The 1988 and later housings have some webbing on the bottom side of them. The only difference in the master install kits is the inner pinion bearing is larger on the later axle and everything else is the same.
  4. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
  5. sweetk30
    Nov 1, 2004
    25,538
    538
    horseheads , ny 14845
    not always true. i have seen up to 96-97 with old style drums. 50/50 shot for pop off drums.
  6. goldwing2000
    goldwing2000 Guest
    K. That's good to know.
    I guess the best way to ID an axle without any chance of mistakes is to pull the numbers off the top of the right side tube.
    There should be a date code in there (I think) but if not, have the dealer run them.
  7. sweetk30
    Nov 1, 2004
    25,538
    538
    or pop the cover and inspect it and then read the ring gear stamped # as there is a date on them if thay are origanal. get ya real close.
  8. goldwing2000
    goldwing2000 Guest
    As you implied, gears can be changed. Housings? Not so much. :D
    Still and all, the link that CB77GMC provided gives about the best way to visually identify between early and late axles. The heavily finned center section is a dead giveaway.
  9. CB77GMC
    May 6, 2005
    771
    Heath Springs, SC
    Where can I find code break down ?
  10. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    96 and up has a different pinion seal then the earlier years.
    Do you have a picture of it? If your unsure pull it apart and check which bearing it has.
  11. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Here's a good shot of the extra webbing on the 89+
  12. sapper
    Jul 11, 2001
    3,052
    NoVa
    That pic clears it right up, the axle is from Boyce so none of it but the housing is original, thanks for the input guys.
