Noob U joint ?
Discussion in 'The Garage' started by Chrisblazzer89, Feb 4, 2007.
  1. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Ok just got my 3/4 ton axles put in and noticed I needed a new front driveshaft U Joint so I went out and got one its to late to put on. So this will be my first time replacing a U joint and was wondering how to grease it I bought a new grease gun too. I noticed that the U joint has 2 threaded holes and it comes with a plug and a grease fitting. So to grease it do I first put the plug in one hole and the fitting in the other install it in the shaft and then conect the gun to it and fill it?
  2. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
  3. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Come on someone help me plz
  4. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    install it into shaft, then install the zerk, compressed air (if present) needs to escape
    never seen joints with 2 zerks, but yeah, plug one I guess
  5. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Do not grease it until it is bolted into your rig. If you do you will push the two caps that are not held in off the cross and then run the risk of loosing a needle.
    Ira
  6. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    It has a threaded hole on one of the caps and then one on the body of the u joint
  7. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    weird ive never seen a threaded whole on a cap before. My guess is install it, grease it with the plug removed till grease comes out the plug hole then install the plug.
  8. OffRoad
    OffRoad 1/2 ton status
    Dec 8, 2002
    852
    New Brunswick, Canada
    is that hand cream beside the valvoline? uh oh.:D
  9. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    :haha: lol Yea I just love wackin it with the valvoline feels so much better:haha:
  10. Jishory
    Jishory 1/2 ton status
    Jan 8, 2002
    1,367
    Palmdale, CA
    if one place is more accesible then the other put the zerk in there, bolt it up and grease it
  11. Chrisblazzer89
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Yea thats wat I was thinking.
  12. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    two things to consider on grease fitting placement. street truck, absolutely install in the cap. so much easier to get to. however, for a one that sees action, put it on the cross. harder to get to, but it won't get torn off if you rub the driveshaft (i'm talking about the rig, here, not your personal habits. don't screw the fitting into THAT at all!!!). i installed one, last week, and my fitting is on the cross. btw, go very easy on the grease. they generally come lubed, to hold the bearings in place, but if you put too much in there, the bearings will not ratate and they'll wear much faster.
  13. goldwing2000
    goldwing2000 Guest
    I've seen axle joints threaded on the caps but not regular shaft joints. Maybe it's a dual-purpose part.
    But yeah, I'd put the zerk in the cross. And make sure you install the joint with the zerk facing AWAY from the axle or you're never going to get a grease gun in there to lube it.
