NOOOOO!! emergency brake.
Discussion in 'The Garage' started by chevysmithz71, Apr 4, 2007.
  1. chevysmithz71
    chevysmithz71 1/2 ton status
    May 26, 2005
    1,464
    Kingsburg, Ca
    Do the disk brake guys wish they had one at times??
    I know that doing the disk brake swap on the 14bolt you feel a big difference. I have the largest of drums on my 14FF, they are huge, (thats what she said)won't they stop just as well as a disk?? The ebrake line gets real tight when I flex out the back 63's, so just not sure If I should run it. If I dont run it, should I just go to disk?
    Thanks yo
  2. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    Love my Disc's. they grab real well and lock up if I get on it hard. I dont miss my Ebrake at all and have wheeled a lot in the last few months without missing it.
    Go For It!
  3. chevysmithz71
    May 26, 2005
    1,464
    Kingsburg, Ca
    What about when you put it in park and feel yourself role back a few inches? Doesn't that put a lot of stress on the tranny. I guess most just try to find flat spots as well?
  4. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    First it's a Parking Brake and not an Emergency Brake;) Second, in the State of CA it is illegal not to have a parking brake. I do think the chance of being caught is slim though.:rolleyes:
  5. scotto0609
    scotto0609 1/2 ton status Premium Member
    Feb 3, 2004
    1,526
    3
    babylon,ny
    It is a inspection item in N.Y.. At least that is what they told me after my truck failed!
  6. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    I haven't really bothered to pay a lot of attention to it as that's a project far down the list, but aren't there a few companies now with parking brakes on their disk calipers? Higher expense I guess than throwing an old set of fronts on but...
  7. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    it's "Parking brake" on a manual transmission vehicle,,,it's an "emergency brake" on an auto trans vehicle...
  8. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    For what it's worth, just about any inspection will use the nomenclature "emergency brake" whatever :D
  9. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    Dont have one, dont need one. A buddy in new york said he pulls his disc hubs off and puts the drums/backing plates and e- brake back on just for inspection. Sounds like a pita, but he failed inspection, and its the only way to fix the problem for free.
  10. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,236
    284
    San Jose, California
    It's really not that hard to hook up the old ebrake cable to the discs. I guess the calipers are a little more money, but it works ok and you don't have to worry about failing any inspections.
    (I actually don't use it much even though I hooked it up.)
  11. chevysmithz71
    May 26, 2005
    1,464
    Kingsburg, Ca
    I'm not worried at all about an inspection. My question is, Is it worth putting on the e brake and let them Get tight when on the trail. I was thinking about cutting a slit in the bracket just to get the cable out and loose when chance of getting real tight.
    I have had a buddy of mine that lost his brakes on the road and just had to yank the wheel and look for an open field. Thats why I ask If some really need or use it?? OR just screw it and go disk!!
  12. bp71k5
    Mar 31, 2006
    6,236
    284
    Ah, I see. With disc, I'd assume you need an parking brake as well right? Although the kit I got seemed to place the cable mount closer to the front of the truck so it gave me some more slack (about 2"). I'm not sure how good this kind of brake would do in an emergency though. I guess it'd be better than nothing, but how often do you lose brakes on both sides of the MC? Maybe I shouldn't ask?
    Maybe someone offers some extension cables?
  13. AZ79K5Project
    AZ79K5Project 1/2 ton status
    Jan 15, 2006
    2,082
    Arizona
    Not to step on toes - I am on the side of safety. I wouldn't think of running the truck without a secondary brake. Call it a parking brake, emergency brake or whatever floats your boat, I will spend the money and do it right.
    Anyone ever see that old video of that Blazer that came down the hill in Colorado or Utah and lost the brakes? Bounces over a couple of bigger bumps and goes nose first into the ground. You may only need it one time in your life, but that one time may keep you or someone else around for another day.
  14. bp71k5
    Mar 31, 2006
    6,236
    284
    That's certainly a good reminder and I completely agree on safety. I'm just not so sure these little parking brakes on disc conversions actually do much more than keep the truck from rolling down the driveway if you shift into N instead of P. I don't think mine would hold on a hill. Maybe it's not calibrated right. I'd recommend putting my $ and time into making sure the "real" brakes are safe and up to par with the rest of the truck.
    Now, my experience is based on the disc brake conversion, so the pressure to the rear is reduced by around 50% with the proportioning valve used by discs, but I guess if you stick with the drums, the parking brake may be more effective?
  15. Kyle Strong
    Kyle Strong 1/2 ton status
    Sep 26, 2005
    280
    Eugene, OR
    I don't have one in my blazer, and I still have the drums. There are times when it's a little unsettling not having one when on a hill, but I haven't had any problems yet.
  16. chevysmithz71
    May 26, 2005
    1,464
    Kingsburg, Ca
    I think I will hold off on the disk conversion for a while and see how these massive drums hold, and with an e brake.
  17. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    If your drums work well I would just keep them. Look into getting longer ebrake cables. They probably aren't REAL cheap, but worth it. Discs are cool, but the only reason I went disc is cuz my drums became useless once they got wet.
  18. AZ79K5Project
    Jan 15, 2006
    2,082
    Arizona
  19. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I recall that they had gone up and come back down the Lion's back...and had such a blast doing it they decided to do it again with the girlfirend driving. Being an automatic and not deeply geared the brakes were already very hot from the first trip down. On the second trip down the brake fluid boiled.
    I'm all for safety, but an E-brake would have done nothing to help that situation. At most the rear wheels would have locked giving up even more directional control.
    Rene
  20. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    Wow. Does anyone know how the occupants were?
