NORMAL GEAR ratio for Chevy Suburban rears for 1983 on?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by _DeeVee8_, Oct 12, 2000.
  1. _DeeVee8_
    _DeeVee8_ 1/2 ton status
    149
    i WANT to know what gear ratio gmc /chevy suburbans ran for 1983 rears normally?
    and What about using a VAN rear end? are these chevy counterparts as tough? do you ahve to reset the spring perches to use them ? What have you all found as far as use of these rears?
    "I suffer from CRS; Can't Remember Shi*" [​IMG]
  2. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I don't think there is a "normal" ratio for Chevy trucks. The ratio could be an 2.73, 3.08, 3.42, 3.73, 4.10, or 4.56. I believe the 4.56's were "mostly or only" found in some 1 tons, the 4.10's were generally only 3/4 or 1 tons. The 3.08's and 3.42's do seem to be the most common available in junk yards for the 1/2 ton stuff.
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Look in the glovebox for the RPO codes here they are:
    GU2=2.73
    GU4=3.08
    GU6=3.42
    GT4=3.73
    G80=Gov lock posi
    90K5
  4. James90
    James90 1/2 ton status
    May 18, 2000
    986
    Rocky Mount NC
    90K5 my blazer has both GU2 and G80 what dos this mean?
    thanks
    [​IMG]Go prepared
    I have a Shotgun a Rifle and a 4WD(K5) and Country Boy Can Survive!!!!
  5. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    It has 2.73 gear ratio and a limited slip differental.
    90K5
  6. James90
    May 18, 2000
    986
    Rocky Mount NC
    thanks
    [​IMG]Go prepared
  7. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    In 1986, a 3/4 ton suburban came with 3.42 gears. If you wanted anything else, it was a costed extra.
