normal heads on a TBI block/ searched, just double checking
Discussion in 'The Garage' started by Okiemuddog, Nov 6, 2003.
  1. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    OK I am going to buy a TBI short block to put my 2.02 heads on,I know I will have to buy another flywheel and possibly an electric fuel pump. The main question is will normal SBC heads bolt directly on a TBI block. TIA
    Krennen
  2. chevystepside
    chevystepside 1/2 ton status
    Sep 23, 2002
    147
    leadville colo
  3. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    yes
    [/ QUOTE ] yes /forums/images/graemlins/rotfl.gif
  4. Kyle89K5
    Kyle89K5 1/2 ton status
    2,273
    OKLAHOMA
    Hopefully someone will correct me if I'm wrong, but I don't think you'll need a new fuel pump. You should be able to pull the block off plate off and use a mechanical pump.
    Again, I may be wrong, but aanyone want to chime in and either confirmor deny?
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    There were some blocks that still had the mechanical fuel pump set-up built in and then there were also some that didn't.
  6. Kyle89K5
    2,273
    OKLAHOMA
    That's what I'm thinking. I know that on both of the 89 blocks that I had, they both had block off plates. I'm just not concrete on which years did and didn't.
    Thanks Mike.
    KP
  7. dyeager535
    26,978
    If you look around, for a bit more, you could be into a factory roller cam block. /forums/images/graemlins/smile.gif
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I know I've said it before, I wish I went with a factory roller block but then again its still not a big block.
