"normal" knock sensor counts.......
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by coyle13, Jun 10, 2004.
  1. coyle13
    coyle13 Registered Member
    Jun 5, 2003
    91
    Albuquerque, NM
    \"normal\" knock sensor counts.......
    I am trying to track down an intermittant loss of torque and power, and I think I have it narrowed down to the ESC system. I have an Autoxray scanner and was wondering what are the "normal" values associated with spark knock count? /forums/images/graemlins/thumb.gif
  2. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Re: \"normal\" knock sensor counts.......
    I think your not supposed to have a knock signal for more than 5 seconds. It is normal to have a knock, and the computer will even set a code for no knock signal at WOT. Well CK5 erased the educational post I had only a month ago on this subject with a plethera of info, we'll just have to repeat ourselves more.
  3. Ryan B.
    Jul 18, 2001
    5,693
    CA
    i don't know about normal knock counts.. but I was getting a detonation sensor error... and i could feel the engine wasn't running right, some lack of power...
    Well i found the cause was the wire going down to the knock sensor rubbed up against the headers and melted the insulation, shorting the knock sensor wire... This threw the code and pulled a lot of timing out of the engine.
