Normal to smell exhaust fumes after I shut down my Jimmy?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by GM Man, Mar 16, 2003.
  1. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    Lately I have noticed that when I shut down my 78 Jimmy I can smell gas fumes pretty strong. Not all the time, just some of time. I checked the fuel line going up to the carb and it is dry and I dont smell anything under the hood. It seems like its all around the gas tank. I replaced the gas cap and one of the rubber return lines with no luck.
    Is this normal or do I have a small leak somewhere?
    Thanks.
  2. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    Check your fuel lines coming off the tank.
    I had the same problem last summer for about a week before I noticed the pool of gas in the driveway as I backed out.
    The return line was dry rotted.
    If that is the problem, it's a really cheap fix. The only problem is that you will most likely have to drop the tank.
    As long as you are at it, replace ALL the rubber fuel lines under there.
  3. GM Man
    Jan 12, 2003
    549
    Denver CO
    I kinda figured I would have to drop the tank, I was only worried about it catching on fire /forums/images/graemlins/eek.gif Dont want that to happen!
    Thanks.
