NOT a Gas Prob. Maybe Exhaust?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DuneRunner, Aug 19, 2001.
  1. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    I posted a message about the gas problem. I changed all fuil filters, and new spark plugs.
    And that's not it. What else could it be? Tomorrow I am going to check the timing and check all of the vac hoses. If not we are going to be calling some SHOPS.... I don't wanta but thats the only other option.
    I have noticed smoke from the passanger side exhaust manifold I believe that it could be loseing pressure.
    What do yall think?
    KEN
    DANGIT it's not a bronco!
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I must have missed your post(or forgot about it[​IMG]). What's going wrong?
    <font color=red>PHOTO ALBUM-</font color=red> <a target="_blank" href=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</a>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  3. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Well starten is fine in nutural its ok but in gear and stoped she is sputtering and some hesatation. I can feel the motor shacken. at freeway speeds its fine it is only at stops. Yesterday I put my finger in the exhaust tail pipe and rubed the inside it came out pretty black.
    So do you think maybe to hi or lean? in the carb. I had it rebuilt 2yrs ago.
  4. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    well if your sure its from the gas then black mean to rich... But i would say its in your timing... im beting that where your problem is..
    Prembird
    [​IMG] <font color=blue> If it aint</font color=blue><font color=red> LOUD </font color=red><font color=blue> Then turn it </font color=blue><font color=red> UP</font color=red> [​IMG]
  5. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    You know I'm keepen my fingers crossed that is what I'm thinken the timing, and tomorrow that is all that I'll be thinken about at work. I was going to do it tonight but ran out of daylight and it was getten cold. Luckly I have another means of transportation... the gas saver honda:)
  6. Can Can
    15,552
    136
    It could also be a vacuum line that's come loose, or a dead EGR valve. Bad idle often stems from EGR problems. Keep us posted as to what you find out.........
  7. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    Will do!
    Time to hit the sack. Morning comes early in the Damb Silicon Valley :-($#!t)
  8. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    FIXED IT !!!!!!!!!!! TURNED OUT IT WAS A DISCONNECTED VACUME HOSE ON THE MANIFOLD BETWEEN THE CARB. &amp; DISTRIBUTOR. RUNS GREAT NOW.
    Ken
  9. Can Can
    15,552
    136
    Like I said- sounds like a vacuum line that's come loose!!!!! Good job with the fix!!!!
  10. dyeager535
    26,982
    191
    See, now you can go back to that "bad" AM-PM gas : ) (which if you figure 87 octane in a 31 gallon K5 tank, saves you about $3 a fill up compared to other stations)
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  11. DuneRunner
    Aug 1, 2001
    1,252
    Fremont CA
    When I read this for the first time it made me LOL at work.
    Ear to Ear :) And with that $3 dollors extra I can save for other mods... Thanks for the help...
    KEN
