Not a K5 but you guys are the best!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by CrazeeBush, May 24, 2000.
  1. CrazeeBush
    CrazeeBush 1/2 ton status
    Apr 17, 2000
    464
    Middle Tennessee
    OKay, my questions is this. I have a 89 s10 blazer and it failed emmisions horribly! Like double the allowed. It has a new motor and I imagine that it has to do with a faulty sensor and the computer compenstaing for it. Any ideas on what to check would be GREATLY appreciated! I'm stumped on this one.
  2. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    Check the codes stored in the computer it will tell you if there is anything wrong that it is connected too.You will have too check a manual but theres a plug like thing under and too the right of the column right under the dash.You can jumper certian pins too get the codes then check the codes.But like i said get a manual.
  3. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    If the motor is brand new, the pistonrings/cyllinderwalls may not be worn in correctly yet. That takes a couple of miles. I know my wife's car took a litle time before the levels dropped.
    [​IMG]<font color=blue>Espen88k5</font color=blue>
  4. getsome
    getsome 1/2 ton status
    107
    Colorado
    The last time that I went to have my Blazer inspected I told them that I was planning on putting in a new engine and they said that they won't test a "new" engine unless it has at least 500 miles on it. Make sure when you take it in the cat is hot and don't let it sit and idle because you build up emissions. My K5 passed Monday after 11 tries. Good luck!
    Getsome
  5. CrazeeBush
    Apr 17, 2000
    464
    Middle Tennessee
    I'm sorry, I didn't mean it was BRAND NEW. It has like 10,000 on it. I'll try and pull the codes to see what it's got going on in there. Last time it went through emmisions it passed with flying colors... Argh!
  6. coopertwpk
    coopertwpk 1/2 ton status
    Mar 18, 2000
    478
    Spring Valley Lake Ca.
    first replace the oxygen senser ,How is it idling ?if the temp sensor in front of the Tbi isnt working it will run rich trying to warm up the engine ,what is your temp reading?this motor doesnt have an air pump right.also have the cat checked mine clogged really bad.
  7. mrkay
    mrkay Registered Member
    Mar 21, 2000
    44
    Plymouth, Ma.
    I got excellent advise from this group on my high idle problems. You're in the right place.
    My NOx was too high and it was caused by the EGR unit vacuum line being disconnected. I think you may have a vacuum controlled system too. Also, as stated by someone else, the hydrocarbons will go way up if you idle too long before going into the inspection station.
    It took me three trys to pass Mass. inspection this year.
    mrkay
    Rock climbing on Plymouth Rock [​IMG]
    with my 88 Blazer 350/Auto/TBI
