Not fullsize but need help with 4.3TBI problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Nrose07, Jan 23, 2002.
  1. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Friends 95' S-10 2WD Vortec TBI 4.3 The problem is magically overnight it started running like [censored]. Cranks, fires, but seems to run on only4-5 cylinders. So I've checked everything, fixed a few problems on the way but still hasen't fixed it. New plugs, fuel filter, gas, plug wires, coil, air filter, cap/rotor. I can drive it ok if I drag the brakes and keep on the gas. It runs ok with throttle and a load, but not at a idle. Got spark, got fuel and its smooth on the road. Engine code 32 is coming up, EGR system. Need some input, Thanks Guys!
    Displacement, cubes, and did you say you drive a riceburner???
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Remove EGR valve and clean inspect, test for function (put vacuum on it). If it looks OK, probably is the EGR soleniod which puts vacuum to the EGR. All this is assuming the system is like my 93 7.4L TBI.
    <font color=blue>azblazor</font color=blue>
    <font color=orange> 79 K5 454-FI / 4L80E, NP205, D60, FF14, 4" lift, 9K Warn </font color=orange>
  3. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    EGR could definitely be the culprit.
    Were any of the plugs fouled when you pulled them? Symptoms sounds similar to my truck when I had a fouled plug. It would shake at idle and cruise, but as soon as the torque went up (and the current went up), the problem stopped.
    <font color=blue>Brilliance is like 4wd, it allows you to get stuck in a more remote location [​IMG]</font color=blue>
