not getting fule, borken lower shock mount
Discussion in 'The Garage' started by djohnson, Aug 20, 2005.
  1. djohnson
    djohnson Registered Member
    Aug 20, 2005
    21
    Denver
    Ok so i'm new to this site and wated to see if this may help answering a couple of questions.
    #1
    I recently bought a 89 Blazer (after looking for quite a while) the other day it didn't start. weird it has always started on the first turn of the key after some diognostic work (by myself) i noticed that it was not getting fuel. Looking for the easy fix i replaiced the fuel pump (not fun time), got it all back togeather and still no fuel. called a machanic he said check the fuel pump relay. great no idea where that is even after looking through my chilton manual (wiring diagram is crap) So any advice on where to find that would be apriciated or any ideas on what else to check would be great.
    #2
    Ok i'm stupid my fault i didn't look over the suspention well enough one time befour i took it down a trail. The nut on the bolt on the driver side lower shock mount must have been lose, it fell off and the blot moved past one of the sides of the mount and when i was bouncing around it broke the inner side of the mount-- long story short i have a broken suspention mount (the one that is welded to the axle, great) any idas on the best way to repair this would be helpfull. figured i would have to cut one off another truck and weld the good mount on to the axle. if there is a better way to do this or if there is somewhere i can find a new mount please let me know, am also going to build this truck up quite a bit so i dont know if it is just worth beefing up the axle now
    any help would be great thanks in advance, need to get this truck back in good form before labor day -- going to the north sand hill for some fun.
    David
  2. Big89Burban
    Big89Burban 1/2 ton status
    Jul 19, 2005
    143
    Magnolia, Tx
    Just replaced the fuel filter on my truck cause it was getting hard to start/sluggish. Damn thing was plugged up completely.
    Might try that since there only like $5.
    Did you check to see if the fuel pump is getting power?
  3. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    What fuse?
    The fuse block should be labeled and tell you what fuse does what. I would scope out that filter also. There is also fuses for each injector of the TBI system. They're usually rated at about 3 amps, and marked "INJ".
  4. djohnson
    Aug 20, 2005
    21
    Denver
    thanks will replace the filter.
    trying to figure out where i need to check to see if i am getting power
  5. PsychoticDeadGuy
    PsychoticDeadGuy 1/2 ton status
    Jan 8, 2005
    753
    Fairfield, California
    the fuel pump relay should be on the fire wall. mine is on the passenger side at the top of the fire wall. there cheap, you should replace it if nothing else works
  6. Big89Burban
    Jul 19, 2005
    143
    Magnolia, Tx
    Well. It would be kinda late to try and check at the fuel pump now. Just use a jumper wire across the relay but MAKE SURE TO JUMP THE RIGHT PINS! so you dont let the smoke out of the wires :wink1:
  7. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    First thing, can you hear the pump running when you turn the key? If you can't then look at the relay, fuse or wiring. If it is then look at the filter and lines.
  8. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    Check and see if you are getting spark too. If you're not, then it could be your ignition module and pick-up coil. Also, check your wires on your MAP sensor. Mine were loose and caused me to not get any fuel on my '88.
    Rick
  9. djohnson
    Aug 20, 2005
    21
    Denver
    Thanks for the help The fuel problem is now solved. word of advice pull all the fuses they may not be labled right.
    Parts Replaced
    Fuel Pump
    Fule Pump Relay
    Fule Filter
    Fuse - think that this was the culpret
  10. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    replace filter now, asap,
    then drive and see how it does, if it still has issue of hard to start and such then id say fuel pump is about toast, and its a real common thing on these, happens all the time,. would be time for a new pump, no biggie :D
    good luck
