not lowering t -case w/ 4"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84k5, Aug 5, 2001.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    not lowering t -case w/ 4\"
    i have an 84k5...when the 4" lift was first put on the t-case was not lowered, there were no vibrations. Howerever the front driveshaft did not clear the crossmember, so I ended up lowering it. I am going to modify the crossmember so it clears the driveshaft, will I be ok in the long term without the lowereing kit? Its got a 208 and the stock shafts. Thanks for any input.
    Brian
    <a target="_blank" href=http://84k5.coloradok5.com>84k5.coloradok5.com</a>
  2. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Re: not lowering t -case w/ 4\"
    You should be ok. So are you just going to lower the crossmember to clear the shaft?
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  3. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I drove mine around for about 3 months before I lowered mine. I was hitting the exhaust. I thought it was no big deal. I changed my gears and rebuilt my c-v joint at the same time. About a month later my C-v joint blew out. It was because it was hitting the exhaust and would put a wierd bind on it. I fixed the exhaust and lowered the t-case now.........Dan
    If it ain't broke.......Don't fix it....
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My truck has had a 4" lift on it since January and I still haven't lowered the transfer case. It's somewhat annoying to listen to the crossmember rub the driveshaft but I'm just too lazy to do it. I guess I'll do it when I swap my frame out.
    Tim
  5. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've never lowered mine, and I run a 4" Superlift. My driveline never has rubbed (knock on wood), so I'll just leave it be.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  6. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Just drop the it down, it doesn't take too long and you'll be happier knowing that it's done !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
  7. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I agree with riz. I drove around for a few months before I lowered it and it was always in the back of my mind that I should. You just feel better once you do. I did it by my self in less then 20 minutes. It is easy.......Dan
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> It should be just another step in doing a lift, like putting on the shocks, ya know what I mean ?
    L8r,
  9. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    OK - why not? I'll do it this week when I change the output seal on my T-case (again)[​IMG]
    Friggin Silt![​IMG]
  10. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I guess my post is somewhat unclear...My driveshaft is rubbing now and i already have the transfer case lowered...I'm going to cut a hole in the crossmember so it clears...I figured I might as well get rid of the drop and gain the 1" of clearance back.
    Brian
  11. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Keep it lowered and cut the cross member.....02..........Dan
  12. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    How do you lower it?
    1984 K-5
    4" lift
    35x12.5 MTs
    buildin a 400 for it, any info greatly appreciated
  13. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    I'd say you'll be fine. If you didn't have vibes before &amp; you're modifying the cross-member to avoid the contact, then why lower it?? It's only robbing the ground clearance that you put in a lift &amp; bigger tires to gain! As far as the angle on the u-joints, the difference in an inch is minimal &amp; if there's no vibes, then things should be fine.
    Just for the record; I'm putting in a 6" lift on my custom frame &amp; I'm NOT going to lower my t-case. If anything, I'm going to try to raise it to be flush with the bottom of the frame rails. I'll also be stretching my wheelbase a few inches to help with driveline angles. Like I said; I just can't understand why you would raise a vehicle &amp; lower it's undercarriage??!!?? [​IMG]
    Brian
    89KBlazer
    Build it Right or Don't build it at all!!
  14. Mreetz
    Jun 26, 2001
    1,282
    Anyone have any pix of a lowered T-Case?
    1984 K-5
    4" lift
    35x12.5 MTs
