not running right
Discussion in 'The Garage' started by hpuall, Sep 21, 2005.
  1. hpuall
    hpuall Newbie
    Jul 24, 2003
    nc
    ok heres the problem '78 350 3spd manual just out of the blue one day she started missing and missing bad. Engine runs fine at idle and revs up like normal in nuetral but once she gets going first gear is fine but in second and third unless u really, really ease into the throttle she starts to miss. Acts like it gets worse the warmer the engine gets too. First thought i might have been a bad tank of gas with water in it or fuel filter prob but both those theories turned up negative. Best geuss now is a distributer prob but not sure wondering if u guys had any advice, thanks for the help
  2. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    cracked dizzy cap? I had that problem on my old truck and thats what it was. I'm sure the experts will chime in here soon.
    timing good and all that? wires and plugs good? fuel filter?
    just some things to check
  3. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Might have fouled some plugs... not much to say here except the usuall ignition checklist.
  4. dyeager535
    26,978
    Not sure why if it were ignition it wouldn't runbad under load OR in neutral.
    Not something basic like timing or choke is it?
  5. mudtrux
    mudtrux Newbie
    Sep 22, 2005
    4
    Mn
    Deffinatly would think ign. 1st. Inital thought is plug wires. Also may hava bad rotor and or cap. plugs wouldnt hurt eather if there old or been droped on the concrete (yes I've done it) Good luck
