not so good
Discussion in 'The Garage' started by dheavychevy38, Nov 2, 2003.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    when i was checking over my truck i noticed that my steering box was bad the frame is cracked and one of the shims to pitchthe diff was cracked in halfany body have this happen to them
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    The frame cracking by the steering box is a common issue with our trucks. You should check out ORD and see about getting one of these products. That is if it's not that bad yet. Sounds like maybe you might need more then a brace if I am picturing what you are saying right. /forums/images/graemlins/tongue.gif
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    The steering box thing is very common. Get it fixed ASAP!!
    The kit can be purchased here. Not sure on the shim I'm sure it prolly has happened to somebody else though. I think echobit sells shims. /forums/images/graemlins/thumb.gif
  4. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    the crack is very small easily fix going to order the kit for it but i need to find the right shims cause those ones came with the superlift 8 inch kit so i'm not sure what degree they are or anything
    when i fix the frame i am going to replace the box cause i gives me a bad wobble and the steering wheel will change places after a hard day of wheeling
