Not Starting After Mods????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by magnum4x4, Oct 12, 2004.
  1. magnum4x4
    magnum4x4 Registered Member
    Jan 4, 2004
    97
    Baltimore, MD
    I just installed an alum. Intake and headers. Now when I try to start the engine it shoots flames out of the carb. I tried adjusting the timing and messing with the carb a little. Also my plugs stick out too far for the headers, do they make shorter plugs for header applications. An info would be a big help.
    73' K5 w/ 350, Edelbrock Perf. Intake, Holley 4bbl, Headman Headers.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sounds like you reinstalled the distributor 180* off when you swapped the manifold. The motor will try and backfire threw the carb or throttle body when you do that. Ask me how I know /forums/images/graemlins/whistling.gif
    Accel and maybe a few others make header plugs for headers.
    Harley
  3. Stickseler
    Stickseler 3/4 ton status
    Mar 23, 2001
    6,503
    Northern Virginia
    I just got a set of accell plugs with my wires that says short for headers. they are for a 454 but I think they are the same If your interested
  4. magnum4x4
    Jan 4, 2004
    97
    Baltimore, MD
    Harley
    I made sure I installed the distributor in the correct position. I marked it before I removed it. Anyone else have any ideas. BTW How do you know?
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yea 180* off, backfireing through the carb.
  6. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You may have marked the distributor body in relation to the manifold or some other referance point but what about the ignition rotor location? If it is anywhere but where it should be it may not start and will possibly backfire on you.
    SO, i concur with the others that your distributor timing is off. Maybe it's not off 180* but it does seem to be off. /forums/images/graemlins/thumb.gif
  7. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Did you take the cap off and look at where the rotor was pointing before you pulled the distributor out?
