Not Starting!!!!!!!GDI
Discussion in 'The Garage' started by wahbob, Mar 2, 2003.
  1. wahbob
    wahbob Registered Member
    Dec 27, 2001
    76
    Austin,Texas
    My 79 k5 wont start it just makes a grinding noise when i try to start it-its not the starter i just replaced it sounds like something else. 350/350 Any ideas ?
    thanks in advance,
    Mike b.
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    grinding noise /forums/images/graemlins/shocked.gif...have you pulled your inspection plate to verify your not eating the teeth off your flywheel?
  3. wahbob
    Dec 27, 2001
    76
    Austin,Texas
    Yeah i have no cover on my flywheel so i can see it pretty clearly. There are some shiny spots where i can see the starter has made contact but they dont look worn or broken!
  4. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    and your sure that your starter is engageing properly. if the soilonoid (sp?) is not pushing the starting gear far enough it would just sit there and grind on the edge. did this just start on day or are you in the process of replacing starters?
  5. wahbob
    Dec 27, 2001
    76
    Austin,Texas
    last week when it was cold i tried to start it and the teeth on the starter broke shattered blew up. i replaced the starter and now this happens? dunno
  6. wahbob
    Dec 27, 2001
    76
    Austin,Texas
    Btw thanks for the fast replies
  7. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    i would first look at the spacing on the starter base. maybe the new starter needs shims were as the old didn't. i had this circumstance occur on another car. you can get a shim kit and try to correct this. or...you can take the starter back and find a different manufacturer to see if it will fit better.
  8. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    what brand of starter are you useing? /forums/images/graemlins/ears.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  9. wahbob
    Dec 27, 2001
    76
    Austin,Texas
    Ultima from oreilly's
