not sure how to fill my 241 C transfer case.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Marshall, Mar 15, 2003.
  1. Marshall
    Marshall 1/2 ton status
    Apr 8, 2002
    204
    LiveRmore,CA
    I am not quite sure how to fill my 241 C transfer case....i know it sounds stupid but if its up to the fill plug is that full or should there be more than that or less?
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Just take out the fill plug on the back of the case and fill it up to that point with ATF. /forums/images/graemlins/thumb.gif
  3. 84K5cedric
    84K5cedric 1/2 ton status
    Aug 2, 2002
    279
    Austin, TX 78660
    fill it to the bottom of the fill plug hole... stop when it starts coming out the hole... make sure you are on level ground.
  4. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Theres a plug, I think its a 31 or 32 mm if I can remember correctly, that you take out. Fill up with ATF until it starts to come out. /forums/images/graemlins/thumb.gif I do it all the time since mine leaks and I dont feel like tearin apart the trans case.
  5. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    30mm /forums/images/graemlins/deal.gif
  6. daleearnhardt01
    Aug 29, 2002
    3,223
    Richmond, VA
    I knew it was somethin in the 30's /forums/images/graemlins/grin.gif
