not sure what i need for the front
Discussion in 'The Garage' started by rerun93, Jan 10, 2005.
  1. rerun93
    rerun93 Registered Member
    Dec 3, 2004
    98
    chico, ca
    ok iam not to sure what everyone uses. but basically i want to be locked up front. iam not sure what axle everyone goes with, as far as i know i have the stock 10b. would it be worth it to get a locker formy 10 bolt or throw another axle under if i should do a new axle what to go with d60? also for this kinda conversion is it bolt on or weld to fit.
    ty
    ReRuN
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Really depends what you want from it. do you really need a front locker?
    If your not sure i would suggest trying a Lockright as they're cheap and bolt straight in. If you really like it and the 10blt can't take your driving style then upgrade to a bigger axle.
    If you hate it you can go back to an open diff no problem.
    I think Tim can do Lockrights for around $240 but PM him for his best price.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I'd go lockright in the 10 bolt and see how it holds up. If you are running 33s like your info says I'd stick with the 10 bolt. I wouldn't run a 60 or 14 bolt with 33s myself cause of the lose of ground clearance.
  4. rerun93
    Dec 3, 2004
    98
    chico, ca
    well i plan to go 35's when i wear out these 33's but yeah iam pretty sure i want my front locked. i think i will go that lockrite up front and see what i can brake.(only excusess to give to the wife to buy stuff with no hassel hehe)
  5. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Ive seen a few people blow up warn hubs, shafts and ujoints on a locked 10bolt.
    Mainly depends on yer driving style.
