Not sure where to hook-up heater hose?
Discussion in 'The Garage' started by Scott A, Nov 2, 2003.
  1. Scott A
    Scott A 1/2 ton status
    Apr 18, 2002
    129
    Monrovia, CA
    I sure would like my heater to work... Can someone tell me where to hook-up these 2 hoses on my 83 Blazer 6.2L Diesel... It was like this when I bought it.
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    See the heater hose that runs from the intake to the radiator? That is connecting the two fittings together that need to run to your heater core.
    Get yourself a 5 foot piece of 5/8" and a 5 footer of 3/4. Run the 5/8" from the intake to the heater core's smaller tube and run the 3/4" from the larger heater core tube to the radiator and you'll have heat!! /forums/images/graemlins/grin.gif
  3. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    You should fill out your profile. I was just wondering what part of the country you are from? Was the PO from the same part of the country? Does it get cold there? I would be asking myself why he bypassed the heater core. /forums/images/graemlins/confused.gif It don't sound good. Also one of the heater hoses can be hooked to the waterpump instead of the radiator and you will get more heat. Then you take the hose coming off the radiator and put a plug or bolt and silicone and hose clamp it in with a 3" long peice of heater hose. I'd get the plug from the parts store.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Since that radiator part is the return line for the heater core, I can't see how you'd get more heat hooking it to the water pump. Either way the hot water is coming from the intake, that side is simply a return.
  5. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Hope it isn't disconnected like mine is because my motor gets hot with the hose connected to the core, don't have it figured out yet.
  6. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    seemed to make a little difference on mine but I can't say I took measurements. Just felt warmer. Probably makes the engine run a little warmer.
  7. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I have my return line on the radiator. I have in the past put it on the water pump and the engine ran a lot warmer. Once I bo0ut my service manual, I found out that trucks with auto trannies had the return line on the radiator. Maunal's have it on the water pump. Until then I didn't understand why some people had the return line it the different location. Never occured to me, the tranny cooler.
  8. cybrfire
    Dec 15, 2002
    15,142
    568
    Iowa
    Maybe that is something you could do in the winter and then switch back if your engine runs too cool. Like the cardboard in front of the radiator, just looks nicer. /forums/images/graemlins/thumb.gif
  9. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    Ok, thanks to '84_Chevy_K10' I got it hooked up. But, when I turned the heat on it was dripping on the passenger side floor?? So, I turned the heat off and the dripping stopped... Any suggestions?
  10. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    sound like you need a heater core, that explanes the bypass
  11. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Hmmmmmm...... I'm willing to bet that the PO didn't feel like replacing the heater core so he simply eliminated it from the system. You guys in CA don't need heat anyways... /forums/images/graemlins/wink.gif /forums/images/graemlins/rotfl.gif
    Are you sure the leak stopped when you turned off the heat? Normally a cracked or leaking heater core will leak regardless of whether the heat is on or not..... /forums/images/graemlins/confused.gif
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    [/ QUOTE ] Bull sh!t, it's like 38 degrees outside with the wind blowing like crazy. /forums/images/graemlins/grin.gif
  13. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Heck that's a warm winter day around here, time to get out the shorts for that.... /forums/images/graemlins/grin.gif
  14. Scott A
    Apr 18, 2002
    129
    Monrovia, CA
    Yes, the dripping stopped when I turned heater controls to off...
