Not trying to steal anyone's thunder but....
Discussion in 'Pacific Region' started by shane74, Mar 4, 2003.
  1. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Not trying to steal anyone\'s thunder but....
    I am making a heavy duty tie rod for my rig similar to the Rockstomper units. Here's the deal. I can get better pricing on the tube the more I buy. I will be using the 1 1/4" x .219 tube. I will be using (1) right hand ends, and (1) left hand end. If I can get some folks to go in on the material with me, I can get them drilled and tapped and ready for the ends. I will supply you with the tie rod part # so you can then install it as you get the $$. The total cost of the machined and threaded tube should be less than $50. The tie rod ends are about $25 each from Napa. That means a heavy duty tie rod for right around $100. Any takers? I will be doing this anyway, but I figured I would see if anyone else wanted in on the deal. I will probably be making them next week if I can get the tap from Shane/Kenny. No not me...the other one! /forums/images/graemlins/grin.gif
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Re: Not trying to steal anyone\'s thunder but....
    What size thread are you using? If you plan to use the std GM ends I know there is a guy on the OBH list with both RH and LH taps.
  3. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    The thread is the standard GM 7/8 x 18 tpi. Since the left hand thread is so expensive, I was just going to use (2) right side ends. I'd use the left hand thread if I could get my hands on one.
  4. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    Funny you should bring this up..........I want one. Firm order - and I'll be ready for it any time you are done. I was gonna order a Rockstomper Rock Rod (like I put on my K5) but no need on the Burb. /forums/images/graemlins/cool.gif
    Get the LH tap and I'm in..........
    Let me know...........
  5. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    IT would be better if you got the left hand tap. Doing a alingment would suck with two right had tie rod ends it would be a guessing game and the alingment tech would not be happy.
  6. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Thanks to Kenny, we will have the correct taps both left and right hand thread. Kenny YOU ARE THE MAN!! /forums/images/graemlins/cool.gif /forums/images/graemlins/pimp1.gif
    I hope to start producing these within the next week. It depends on how fast Kenny can get the taps. Kenny PM me with shipping costs so I can cover them.
    Also, just so everyone knows, the guy who will be doing the machining builds custom cars, trucks and hot rods. His work is VERY meticulous. These will look GREAT and be VERY functional too.
    I will be building a first proto type. I'll take pics for everyone to see and then if people are interested I'll start taking orders.
    Frank & Kenny, if you trust me, I'll make yours at the same time I do mine.
  7. kennyw
    Jun 9, 2002
    13,223
    94
    Machining? I thought you were talking about taping the end of a piece of DOM tubing /forums/images/graemlins/smirk.gif No machining required here. A monkey can tap a straight hole if the pilot is the right diameter /forums/images/graemlins/thumb.gif
    The guy willing to loan out the taps is leaving on vacation and said he would be able to look for the taps the weekend of March 15th when he gets back.
  8. BurbinOR
    5,829
    Oregon
    Shane, I trusted you with my life installing the lift on the Burb.........OF COURSE I trust you! /forums/images/graemlins/smile.gif Count me in as a firm order.......if you need the $$ up front let me know.
    Great timing, I was going to order a Rock Rod TODAY.........no more! /forums/images/graemlins/thumb.gif
  9. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    Machining? I thought you were talking about taping the end of a piece of DOM tubing No machining required here. A monkey can tap a straight hole if the pilot is the right diameter
    True, but I am a perfectionist. Also the dom tube needs to the ID bored out so it can be tapped. I want the bore and tap to be PERFECT. Also, the lengths of tube will be rough cut and I want them milled so that the jamb nuts will seat correctly against them. So, that is why I am having them machined.
    Ok, I'll take it however I can get it. The bad part is, that I will be out of town from 3/17 thru 3/28. If I'm lucky, I'll be home the first week of April. I can try to get them done that week if I can get the taps somehow. I have a very short window to do this as I most likely have another back surgery coming up /forums/images/graemlins/angryfire.gif. That will keep me out of comission for months before I can work on anything with any kind of weight to it (even 20#'s will be too heavy for awhile) /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    I'm gonna be needing one too once I get my steering arm.
    Crossover time /forums/images/graemlins/smile.gif also may need a new tie rod, need more beef.
    -Jeremy
  11. Heavymetal
    Heavymetal 1/2 ton status Premium Member
    Mar 30, 2001
    936
    Oregon
    I'll take one if it is the correct left hand/ right hand threading. Just tell me when and where to send the cash. /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  12. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    What will you use for the LH side for a Tie rod end?
    Don't most "hardcore" people use two RH Tie rod ends from a Dana 60?
    Would someone also explain to me why it would be harder to align a rig with two RH Tie Rod ends? (I'd imagine you would just have to think a bit harder and turn one wrench opposite the other /forums/images/graemlins/crazy.gif
  13. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    I will be using a left hand and a right hand tie rod end. These are beefy ends for a D44 (same part works for a 10 bolt. I can't use the ends for a D60 because then the knuckles would have to be re-tapered. These are the exact same ends that others use in their set ups. The reason it is mor difficult w/ 2 right hand ends is because as you turn the tube to adjust one end will thread in, and one end will thread out. When you use a left and a right hand end, as you turn the tube they will both thread in or out equally depending on which way you rotate the tube.
    When aligning, you want each end to thread in and out in equal amounts. This spreads the force through the part evenly. You want an equal amount of thread exposed on each end mainly for strength purposes.
  14. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    You got it! I just need to know if you want the tube only, or if you want a complete unit?? It'll probably be at least a month before I can get all of them made (mainly due to work travel schedule). Sorry! /forums/images/graemlins/tongue.gif That makes a total of 5 so far, I think. I'll have to recount /forums/images/graemlins/tongue.gif. I am waiting on the taps to get here.
  15. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    I thought I read somewhere that people were using Dana 60 TRE from a Dodge, because they don't have the steering dampener hole on them and they are left hand thread - does anyone know if this is true -
    Josh or Shannon - you both have Dodge D60s - how about it?
  16. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    ok i just bought a tie rod from 4x4 iron with rh threads on both ends...cause it was cheaper...works fine just hafta remove the tre from the knuckle to adjust it...took me like 20 minutes to get the toe set....thats all.
  17. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    how much are the rock stomper units they sound exspensive, I am interested too /forums/images/graemlins/grin.gif
  18. shane74
    Feb 12, 2002
    4,100
    Vancouver, WA
    They run anywhere from $155 to $200. Like I said, I am NOT trying to steal business from Rockstomper or anyone else, nor am I trying to start a business. It's just that it's no big deal for me to make up several once I get the lathe all set up and going.
    BTW, just so everyone knows, these are going to be unpainted units. You can paint 'em any color you want once you get them! /forums/images/graemlins/grin.gif
  19. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    My TRE's do not have a hole for a stabilizer,
  20. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    shane did i read correctly that you cannot make tierods for dana 60s?
