Not working
Discussion in 'The Garage' started by grindkings, Mar 1, 2005.
  1. grindkings
    grindkings 1/2 ton status
    Dec 24, 2004
    127
    Marshall, Missouri
    I recently replaced my heater core in my 1991 blazer, pretty easy. However, nowthe blower dosn't work, no air or heat. I'm not really sure where to look for a unpluged wire. I also replaced my steering colum, would there be a wire there that would matter? Not sure. Please lend me some HELP.
  2. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Did you check your fuse? Unless you've 'pinched' a wire putting the column up there's not a lot you could have done.
  3. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    I'll check the fuses today. I was just check to make sure one of the blowe wires didn't run through the colum in any fashion.
  4. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    Look on the right side of the engine near the firewall. Look for a purple wire going from the blower motor relay to the blower.
  5. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    All the fuses are okay. I will check the purple wire under the hood.
  6. grindkings
    Dec 24, 2004
    127
    Marshall, Missouri
    The purple wire IS connected. could the rely be bad?
