Not your average lift ?
Discussion in 'The Garage' started by rockink5, Feb 22, 2003.
  1. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I want to go to 56" rear springs and I have all that worked out. I am using an ORD flip. Problem is thats only 4". I am lifting the front up to 6" and have yet to find a way to get the back up with out a block. I am using 0rates now but it still will not be enough. I can't seem to find anyone who makes a 2" lifted 56" rear. And I am not sure about the whole rearching thing.
    What to do? /forums/images/graemlins/confused.gif
    /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Or you could get the shackles that are made to lower a vehicle (like in Summit) and reverse them for the shackle flip and lift it, that MIGHT work but that's just something that I though of...
  3. cybrfire
    Dec 15, 2002
    15,140
    565
    Iowa
    zero rates plus make some custom spring perches that are 1" taller than factory. Not much different than a block except its welded in. Otherwise you can bring the spring to frame mounts down an inch. Just a couple other ideas for ya. Don't know where to find those springs your looking for.
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    You might try email different spring companys and ask if they have what you're looking for. Just a thought.
  5. Swanson52
    Swanson52 1/2 ton status
    Mar 27, 2002
    2,586
    Centennial, CO
    Some will depend on the ACTUAL lift of the front. I had planned to buy a set of cheap 4" rears and take out leaves to level it out. Skyjacker makes 2" lift 56" springs, but they run about $400 for the pair.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    2" blocks aren't that bad, and if you want you can just weld them on. i know people who have 5.5" blocks, which isn't he smartest idea, but they still haven't had any problems yet, so i doubt 2" will give you any problems at all
  7. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,961
    251
    Released from Pueblo, told I belong in Southpark
    Try alcan springs out of Grand Junction Colorado and bring your visa card
  8. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    [/ QUOTE ] Don't "Add-a-Leafs" give ya 2" anyways ???
  9. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    If you use a lowering shackle to lift it make sure you box it in or it will collapse. As already stated Skyjacker makes a 56" lift spring. You could also go to a spring shop and get yours rearched.
  10. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    That's what I thought and what I planned on doing to my Burb with the shackle flip.
    Brett
  11. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    Its hard to get things to turn out the way they do on paper. When I did my rear suspension I was hoping to get about a six inch lift but I came short about 1.5". I ended up cutting my old blocks to get 1.5" blocks.
    There are a lot of variables that effect the final ride height. Shackle angle, shackle length and spring rate to name a few. I suggest just installing it and fine tune it to achieve your desired height, using longer shackles or adding blocks.
  12. Swanson52
    Mar 27, 2002
    2,586
    Centennial, CO
    That's what I'm saying. Get the 4" Pro Comp 56" rear springs for around $275 for the pair, and take out leaves as you need to. Hell, throw your Zero Rate in the front and level it out.
  13. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Lowering shackles are weak. Use something made for 4x4's like this long shackle for an xj. This warrior products shackle is beefy
