not your normal u joint question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by milspecjimmy, Sep 23, 2002.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    i just recently replaced the rear yoke on my 10 bolt, and put in a POS napa u joint, along with a new set of bands and bolts. after about 3k the darn u joint is sloping around in the yoke and it feels worn out too. my next u joint is going to be a spicer, my question is: has any one heard of yokes wearing out his fast, or u joints being the wrong diameter at the caps? any help or suggestions would be great.
    thanks
    ~~~ jeff /forums/images/icons/confused.gif
  2. BigMac
    BigMac 1/2 ton status
    May 27, 2002
    397
    Fremont, CA
    are you sure it was the right size?
    I had a conversion joint that wsnt big enough on the big end .. I didn't notice till my buddy put in the rear shaft and I gave it a shake.
    when I got the right one it had to be stuffed into the hole. It is so tight it feels like the whole thing shouldn't be moveable.
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    It's the Crappa u joint, trust me.
    Spicer is a wise decision
  4. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Chevy did use different sized caps for a few years, I run into this with my '87. Best bet is to take them in to the store with you.
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    different size as in the known series sizes differences, or do you mean differences in fraction of an inch ?
    i have seen a coupel instances of loose cap in yoke problem,. tighten strap bolts completely and the cap stil be loose in the yoke,,, like by 1/32" of an inch..
    cant get spicer joints around here,... thats probably the problem,.., really sad quality cotrol practice probably.. hmm..
    good luck.
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
