Not your typical U-Joint Conversion Question (UPDATE!)
Discussion in 'The Garage' started by 83ZZ502_Jimmy, Jul 4, 2003.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    See bottom post
    Through numerous searches I have determined that I have a 1330-F U-joint in my 1983 GMC Jimmy. I have swapped some axles around and now have a 1989 10 bolt in the back. It is a 1330 U-joint.
    The 1330-F joint has 1.188 caps and is 3.625 wide.
    The 1330 joint has 1.062 caps and is 3.625 wide.
    Same width just different cap sizes.
    Does anyone know if there is a conversion joint out there that will make this work... If not do I need a new driveshaft?
    Thanks in advance,
    John
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: Not your typical U-Joint Conversion Question (already searched)
    did anyone save my spicer ujoint part book scans before webshots deleted them.
    the conversion pages were amongst them
  3. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,055
    Washougal WA
    just take one of each cap to the parts store and make em start opening boxes till you get a match. /forums/images/graemlins/thumb.gif
  4. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I think the Tech page on Pirate has the Spicer catalog in Adobe format. If you decide to DL, I hope you've got broadband... I DL'd the CUCV tech manuals, and at 200-300 KB/sec, it still took like 10 minutes.
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Nothin' yet /forums/images/graemlins/tongue.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/smile.gif
    John
  6. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    UPDATE!
    This is what I found out. On my 1983 GMC Jimmy, I have the following.
    My original driveshaft has 1350 size U-joints on each end. Funny, yes, but all I can figure is that because it was a manual tranny truck it came with the larger ujoint.
    The 10 bolt that was orginally in the truck was a 1350 size ujoint. Swapping in the later 10 bolt switched it to a Saginaw 44 joint. This is the joint that is in most K5's withnot the 1330 or 1310 for the rear
    I ended up using a Napa 447 because it mated the 1350 driveshaft to the Saginaw 44 yoke on the axle. Note this is also the common joint used to mate a 14bolt to the factory driveshaft in most 10bolt blazers. I just ended up using it the other way.
    On a side note... I did get it installed, then not 10 minutes later broke the joint and the yoke on the driveshaft. So now I need a new driveshaft and ujoint. Arrrgh!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/grin.gif BTW dont run low range on dry pavement and floor it with 570lb ft of torque. It breaks new ujoints.
    So now I will post in the wanted section for a used d-shaft.
    Thanks to all that responded,
    John
