Notebook HDD jumper...
Discussion in 'The Lounge' started by jarheadk5, Oct 10, 2005.
  1. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    Which side should it go on?
    Looking at old drive with metal case UP; long row of pins are to the left, jumper pins are to the right.
    Currently the jumper is on the RIGHT-HAND set of jumper pins, but my father-in-law was trying to recover data from this drive, and I don't know if he had to change the jumper or not.
    Anyone know?
    It's a Toshiba 80GB drive, going in a Dell Inspiron 8200 if that matters. There's no guidance on the drive label or in Dell's documentation I've found...
  2. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Jumpers are usually for:
    CS - Cable Select
    DS - Drive Select
    SP - Slave Present
    I've never heard of a "data recovery" jumper... they are typically to help you tell the BIOS whether there are multiple drives attached to a single IDE channel and how to identify each one (allowing the cable to create master / slave priority) or by hard jumpering the drives instead.
    BTW -> A google search of "Toshiba 80GB jumper settings" seemd to find some relevant stuff. Most HDD manufacturers will publish tech specs (with jumper diagrams) on their sites.
    :thumb:
  3. jarheadk5
    Mar 6, 2000
    4,389
    PA
    Apparently I'm Google-retarded (as I already knew... :mad: ).
    I can't find anything instructive on where the jumper needs to go, or if it even needs to be there. The most informative thing I found was a statement in some forum that if there's nothing on the drive label about a jumper, it probably doesn't need one.
    Oh well, gotta go to work anyway... I'll mess with this later. Thanks, Greg!
  4. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    Ive never used a jumper on a laptop drive... Try it without it or experiment. It shouldn't damage the drive if you try it in different positions.
  5. botboy
    botboy 1/2 ton status
    Aug 11, 2004
    225
    Delano, MN, USA
    Most laptop drives are default either CS or master, I've used a jumper on a lappy drive before but it isn't often necessary...why not use the drive without jumpers on a single IDE channel (I tend to use an external "caddy" to recover stuff from laptop drives when necessary)
