Notes and thoughts on 52" springs up front
Discussion in 'The Garage' started by Sandman, May 2, 2004.
  1. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Notes and thoughts on 52\" springs up front
    Well, I've had a chance to really test these out and I like! I only found one problem;
    I have redrilled my front spring perches to move the axle forward 1.25". This extra amount was enough to move the steering arm into the U-Bolt at exteme stuff and only when the tire is in one position. There would be two ways to fix this, move the axle back to the stock holes on the spring perches or put in a bump stop. I will got he bump stop rought as the tire is alread very close to the firwall when its stuffed and turned out.
    Just somethig to be aware of. Then I broke out the measuring tape. Right now the shock is limiting droop but I think I will not worry about it. My brakeline just gets tightish with the tire all the way down. I could drop the shock bracket down a few inches as the travel is left over on a full stuff. That would gain me some more on the end but then I'm back into brakelines again. So, I'm just going to run it.
    Now how much travel? /forums/images/graemlins/grin.gif
    Try 22" with the shocks being the limits!!
    Works for me. /forums/images/graemlins/thumb.gif
    It doesnt hit, but its real close. I might do some trimming just to be safe.
  2. micah
    micah 1/2 ton status
    Sep 18, 2003
    374
    Austin, TX
    Re: Notes and thoughts on 52\" springs up front
    what size tires are those... i thought you had 39.5's, but those look new. any pics of your core support and firewall up close to show what you did to make clearance?
    i'm on 42's and have 52's up front with 56's in the rear. I haven't had a chance to do a lot of testing in real wheeling, just driveway flexing... I haven't moved my axle forward at the perches, just the couple inches resulting from the spring swap, and i'm already into my core support.
  3. eightyone
    eightyone 1/2 ton status
    Apr 25, 2004
    292
    long island
    i was considering the 52 inch spring swap, what would i have to do to get 6 inches of lift? i have 6 inch sprins right now, could i put 4 inch lift springs from the back into the front? /forums/images/graemlins/dunno.gif
  4. cybrfire
    Dec 15, 2002
    15,143
    579
    Iowa
    what springs did you use up front? More specifically what amount of lift were on them or if they were stock how much lift did you get and are they 4 or 5 leaf packs?
    By the way,
    YOUR BLUE /forums/images/graemlins/grin.gif
  5. micah
    Sep 18, 2003
    374
    Austin, TX
    my stock rear springs moved up front (minus the overload) gave ~4inches of lift. I assume 4 inch rear springs, would net 8 inches.
  6. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What the hell would you know, you damn newbie! /forums/images/graemlins/grin.gif /forums/images/graemlins/wink.gif
    As for the brakeline issue, why not go with a center drop brake line...just like the rear...
  7. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    got a new backround pic /forums/images/graemlins/waytogo.gif
  8. Sandman
    Apr 15, 2002
    5,653
    Pocatello, ID
    The stock rear springs up front gave me about 4" of lift or so. I sawed out everything from the body supports out to make the room. Those are 39.5" tires. I think I can just fit 42" when those wear out.
    I am Blue! /forums/images/graemlins/eek.gif
    Help! I'm a nerd! /forums/images/graemlins/yikes.gif
  9. gm guy
    gm guy 1/2 ton status
    May 1, 2004
    151
    Vancouver Island but work in Ft Mcmurray Alberta C
    I like the body protection, flex is lookin good aswell. /forums/images/graemlins/bow.gif
  10. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    I love my 52" front springs. I just have to be careful cause when the front end bottoms out hard the spring just barely contacts the pitman arm. /forums/images/graemlins/doah.gif So I think when I get my new frame i'll move the steering box around.
  11. Drey
    Drey 3/4 ton status
    May 8, 2003
    8,288
    Iowa
    I got a new backround too /forums/images/graemlins/peace.gif I also think my shocks must be why my flex sucks...that or the sagging springs /forums/images/graemlins/rotfl.gif
  12. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    Im runnin the 52s up front and my shocks are limiting travel severly, so in goes the ford shock towers then i can measure and get long travel shocks.so far i really like the ride on road,and the flex is awsome with the shocks removed...the drivers side spring can hit the drag link at full stuff,so im gonna drop the bumpstops down a bit and longer shocks will happen in a couple days /forums/images/graemlins/thumb.gif..overall for the money im very pleased with the swap...
